HOw does my coolant level look?
Old May 25, 2014 | 07:36 PM
no1joey's Avatar
no1joey is a name known to allno1joey is a name known to allno1joey is a name known to allno1joey is a name known to allno1joey is a name known to allno1joey is a name known to all
This is normal right when engine hot?
Old May 25, 2014 | 07:52 PM
jhbrennan's Avatar
In your owner's manual -
When the engine is cold and the car is level the fluid level must lie between the “MIN” and “MAX” markings.
no1joey's Avatar
Thanks, but the question was relating to a hot engine.
Old May 25, 2014 | 08:02 PM
jhbrennan's Avatar
Since coolant expands when hot, I'd say if you take a measurement while cold you would find the level would be well below Min.
Old May 25, 2014 | 08:10 PM
no1joey's Avatar
Well I've asked my local garage who did a coolant flush a few weeks ago about it (left a msg)... the car isn't overheating though I hope it has enough coolant. I thought maybe the level drops when the engines hot, as it has to circulate around more?...will advise what my garage tells me.
Old May 25, 2014 | 08:11 PM
cab83_750's Avatar
cab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud ofcab83_750 has much to be proud of
At that level (cold), just add distilled water. Of course, if you have the $ to spend, add the 'special' Porsche coolant blend.
Old May 25, 2014 | 08:59 PM
no1joey's Avatar
Yep it was 250ml too low, topped up with demineralized water, will add the same amount of coolant tomorrow when I pick up a bottle from my local dealership.
Strange, I can only put it down to the garage not putting in enough, as I have no leaks, they would of shown up in my car spot.
Old May 25, 2014 | 09:52 PM
Anderson's Avatar
Anderson is infamous around these parts
Best thing is to check when engine is cold, but in your case add some just to make sure.
Old May 25, 2014 | 11:48 PM
spyerx's Avatar
spyerx is a jewel in the roughspyerx is a jewel in the roughspyerx is a jewel in the rough
These systems due to capacity and length are hard to get all air out. After a few drive cycles you may need to top up a bit. Just use distiller water like you did.
Old May 26, 2014 | 06:15 AM
jhbrennan's Avatar
Just keep a watch on the level. Sometimes if a leak is in the plumbing from front to rear you won't see any evidence on the garage floor since the under car panels would catch it. Also, the capacity is 32 liters so I wouldn't be overly concerned being 250ml low. Let us know what your cold measurement shows.
Old May 26, 2014 | 08:32 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
also, the level on these things is especially effected by checking it while parked on even the slightest un level ground.
That s not low enough to be worried about anything. Just top it off with the water and don t even bother with buying the expensive stuff (which you should never need to use anyway)....
Old May 27, 2014 | 12:19 PM
ksdprasad's Avatar
ksdprasad is infamous around these parts
how about poland srping water. just curious.
vogz
Oct 8, 2015 12:02 PM
TOGWT
Detailing
Sep 28, 2015 08:25 AM
