Rear driver window stuck down, any way to lift?
Old Jul 27, 2019 | 04:24 AM
Raym50's Avatar
Raym50 is infamous around these parts
My rear driver window is stuck in the down position. I hear some motor action when I press the switch but it won’t go up. I assume I need to rep each regulator and maybe motor. Until I can get this to repair shop, is there a way to manually lift the window? I don’t want to leave it open or cover with plastic ghetto style.
Also, anyone know of a repair service by the jersey shore that would come to me to fix?
Old Jul 27, 2019 | 05:49 AM
Petza914's Avatar
Petza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond reputePetza914 has a reputation beyond repute
I'd call the closest Porsche dealer and talk to the service manager. Tell him what's going on and inform him you'll need a loaner while they repair yours. You'll likely get to drive a Macan.
Old Jul 27, 2019 | 06:10 AM
Raym50's Avatar
Thanks but I’m not into getting ripped by dealers. It’s a 2006. Out of warranty. Any other thoughts?
Old Jul 27, 2019 | 09:37 PM
sandwedge's Avatar
sandwedge has much to be proud ofsandwedge has much to be proud ofsandwedge has much to be proud ofsandwedge has much to be proud ofsandwedge has much to be proud ofsandwedge has much to be proud ofsandwedge has much to be proud ofsandwedge has much to be proud of
On my third 997 and didn't even know the rear window could be opened and closed. Probably because nobody ever rode in the back of my cars. To your point, If you don't want to spend the money to have the dealer or an indy fix it, all I can think is to start to take things apart back there where you can access the mechanism and hopefully find a way to close the window manually. With any luck you'll also find out why the motor isn't retracting the window. By your account it sounds like the motor is working but not doing what it's supposed to do.
Old Jul 28, 2019 | 05:51 AM
Petza914's Avatar
I'm assuming his car is cab. The rear windows in our coupes don't move but in a cab they do so the process of putting the top up and down doesn't break those small windows.
Old Jul 28, 2019 | 10:33 PM
sandwedge's Avatar
Stupid me. Of course that's what it is. Makes perfect sense. Never had or drove a 997 cab so that's my lame excuse.
Old Jul 28, 2019 | 11:06 PM
ogun228's Avatar
ogun228 is infamous around these parts
To the OP: there is a small switch below the side view mirror adjustment
this switch moves for and aft. Fore: front windows, aft: rear glass. Try that and
your problem should be solved...You can download a manual from just about every
Porsche forum, even this one.
Old Jul 29, 2019 | 02:24 PM
ogun228's Avatar
Switch in question is below the windows lift buttons.
ogun228's Avatar
switch in question is below the windows lifts.
Tintin
Bentley
17
May 11, 2016 12:07 PM
mmmmm
Oct 27, 2015 12:11 PM
