Maintenance costs over 3 years?
Old May 19, 2006 | 12:38 PM
MCJ's Avatar
MCJ
MCJ is infamous around these partsMCJ is infamous around these parts
As I get closer to purchasing a 997S, what kind of maintenance costs can I expect? I've always had BMW's where everything was included so this will be a change for me. If I plan to keep it for 3 years @ 10-12k miles per year, what would I incur in costs (ballpark of course)?
Old May 19, 2006 | 01:16 PM
SD1's Avatar
SD1
SD1 has a spectacular aura aboutSD1 has a spectacular aura aboutSD1 has a spectacular aura about
10K oil change maybe $200??? 20K intermediate service $600?? Call your dealer for more accurate info.
Old May 19, 2006 | 01:17 PM
TripleInboard's Avatar
TripleInboard is infamous around these parts
With that mileage, you could probably get away with only having to do two oil changes, and possible only two tire changes. Anything unscheduled should be under warranty.
Old May 19, 2006 | 01:21 PM
djantlive's Avatar
you should plan to spend 1300-1500/yr covering maint services and new tires. This estimates that you change rear tires every year and one set of fronts.
Old May 19, 2006 | 02:58 PM
MCJ's Avatar
MCJ
Thanks guys.
Old May 19, 2006 | 03:14 PM
MexicoBlue's Avatar
MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !MexicoBlue Is a GOD !
What was the question again ??? Can't focus. Can't think. Staring at avatar . . .
Old May 20, 2006 | 01:03 PM
2thfixr's Avatar
2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold
Isn't the service interval 15k and 30k? The main expense will be tires. Rear tires every 8-10k miles @ $1000 and new fronts ever other set of rears.
Old May 20, 2006 | 02:46 PM
gravedgr's Avatar
gravedgr has a reputation beyond reputegravedgr has a reputation beyond reputegravedgr has a reputation beyond reputegravedgr has a reputation beyond reputegravedgr has a reputation beyond reputegravedgr has a reputation beyond reputegravedgr has a reputation beyond reputegravedgr has a reputation beyond reputegravedgr has a reputation beyond reputegravedgr has a reputation beyond reputegravedgr has a reputation beyond repute
$1000 for rears? Seems a little high. I've never paid over $650-700.
Old May 20, 2006 | 02:52 PM
20C4S's Avatar
screw the maintenance cost. the mod money will suck u dry. don't say no cuz the force is strong.
Old May 30, 2006 | 01:53 PM
raffi's Avatar
raffi is infamous around these parts
i have had my car for alittle over a year, 7k miles, changed the oil myself 3x for around $60 each. thats all the maintenance, which was probably overkill anyways.
probably in 3 years you will have to add one brake pad change and fluid flush, less than $250 if you do it yourself, or $600 at independent shop, $1000 at dealer. maybe tires after 20K mile depending on driving style.
arling is right, these cars are low maintenance. all your money will go on mods, unless you consider mods as maintenance...
Old May 30, 2006 | 06:49 PM
njcl55's Avatar
njcl55 is infamous around these parts
porsche calls for the first oil change at 20k miles... this being my first p-car i noticed people here are changing oil much earlier... should i just follow a normal 3k mile oil change schedule or go with the manual????
thoughts...
Old May 30, 2006 | 10:26 PM
raffi's Avatar
imo if it is your car and not a lease just do the oil changes a little earlier, if you were planning on 20K then why not cut it in half to 10K. I enjoy doing the work so did it much earlier and dont think it will hurt, although some people talk about the myth of special break in oil...
Jul 29, 2019 11:13 AM
turkish1
Nov 11, 2015 09:01 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
