Does your AMV8 brake squeal?
Old Dec 1, 2010 | 07:34 PM
mdc's Avatar
mdc
mdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond reputemdc has a reputation beyond repute
Hi all, does any one here has the same problem? We did not have any problems for the first 1.5k miles, now it is making high pitch squeal coming to to stop sign, red light etc. it is more than annoying at this point ; [, please feel free to share if you have any solution. Thanks
Old Dec 1, 2010 | 08:05 PM
seattle_sun's Avatar
seattle_sun is just really niceseattle_sun is just really niceseattle_sun is just really niceseattle_sun is just really nice
Have you de-glazed the brakes? If you are driving mostly city, the brake pads glaze over. Drive to relatively higher speed and hit the brake hard.
Old Dec 1, 2010 | 11:18 PM
mdc's Avatar
mdc
Thanks, I will try that. It is a daily driver to from work, all surface road driving only.
Old Dec 2, 2010 | 03:19 AM
astondude's Avatar
astondude is infamous around these parts
My car had the same problem but it was fixed under warranty. Apparently, it is a common problem with the brake squeal especially when it's cold. I think the dealer put some shims or something but no new pads. I'm not sure if they put some anti-squeal brake compound.
Old Dec 2, 2010 | 07:01 AM
Swoody's Avatar
Swoody is just really niceSwoody is just really niceSwoody is just really niceSwoody is just really niceSwoody is just really nice
A little bit....when cold out. It seems though after they are warmed up it stops.
Old Dec 2, 2010 | 08:23 AM
flinder's Avatar
flinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to behold
Won't solve dust problem
Under warranty your dealership tech will remove your OE brake pads. He will then apply an extremely thin double backed foam pad to their back sides and reassemble them...problem solved. If they glaze, as described above, a slight squeel will reappear, but nothing like what you are experiencing now.
Old Dec 2, 2010 | 12:13 PM
Michael 996TT's Avatar
Michael 996TT is infamous around these parts
I think flinder has the correct comment - actually vibration of pad when brakes applied that causes the "squeeeel" - seems to be more common w/ cars that are not driven daily. Applying the material (there are various types that work) between back side of pad and cal/piston should stop the sound. This is common and should have been done by the dealer - or did you use someone else? Who ever installed, this material is the norm .... I had same issue w/ P-cars too.
Old Dec 3, 2010 | 05:42 PM
Red Devil's Avatar
Red Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to allRed Devil is a name known to all
Same problem here on a DB9. I had the service bulletin work performed and it worked for a while, but now it's back. Mostly light pedal and low speed. The SA said I should try a couple of bedding in runs, which I'll do one of these days.
Old Dec 30, 2010 | 11:38 PM
mdc's Avatar
mdc
brake squeal - no fix
They suggest harder braking... I am considering headphone while driving.
Old Dec 31, 2010 | 04:53 AM
Red Devil's Avatar
"harder braking" is just another example of manufacturers refusing to step up and fully address a problem. That bothers me more than the actual squeal ...
Old Dec 31, 2010 | 10:02 AM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Most of my squeel is coming from the rears. Replacing my brake pads with carbotech 1521 compound in the next few weeks. I will be doing full writeup on it, but i truly think it will cure all my squeel problems. More updates coming soon...
________
IHNO
Old Dec 31, 2010 | 08:52 PM
scottblack's Avatar
scottblack has a spectacular aura aboutscottblack has a spectacular aura aboutscottblack has a spectacular aura about
Same here. Of course, it does not get cold too often in Texas!
ModBargains
Oct 13, 2015 03:40 PM
oo7
Sep 10, 2015 08:08 AM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
