Locking woes continue
Old Jul 30, 2011 | 11:08 AM
Tahoe M3's Avatar
Tahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really niceTahoe M3 is just really nice
So I'm still having trouble with the locks on my car. It works intermittently, but any time the passenger door is opened everything gets messed up and neither door will lock. It makes it really tough to take the car anywhere knowing that I can't lock it.
I just had the alarm module replaced yesterday...for $550 installed...which didn't help. The passenger side door latch has been replaced before, but obviously didn't solve the problem.
Previously I changed the settings which worked for a while, but now I'm back to square one. Has AM solved this problem yet??
Old Jul 30, 2011 | 11:11 AM
Racer_X's Avatar
Racer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud of
Never heard of this issue before Tahoe. Is it common?
Old Jul 30, 2011 | 12:13 PM
Tahoe M3's Avatar
Unfortunately, yes. There have been some work-arounds posted of other sites, but none of them have worked for me. Next step is to have the dealership reprogram the lock controller.
Old Jul 30, 2011 | 12:18 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Hey tahoe,
Something I noticed when I had my v8v was that the locking problems on our car do not appear to be the latch itself....
Any time I would open and close both doors before hitting the lock button, both would lock every time 100% of the time without exception. However when you would only open one and not the other then one would lock and the other would not.
It appears that each door locking mechanism "resets" every time you open and close the doors. I have no idea why the system works this way but it does. It appears since you replaced part of the system it may be stuck in the opposite position.
The real problem appears to be the door sensors, not the locking mechanism itself. However, the dealer would rather just replace everything for both ease and monetary gain.
For anyone having locking issues, just open and close both doors then lock and see if that solves the problem
Old Jul 30, 2011 | 12:30 PM
Tahoe M3's Avatar
That doesn't solve the problem...in fact, it sounds like mine is the opposite of what you had. I just figured out how to bypass it, and it all hinges on the passenger door. Hand locking the passenger door solves the problem.
If the passenger door is unlocked at any time, the key fob will not relock either door. The only solution is to hand lock the passenger door first, the the fob will lock and unlock the driver door without any problems...open it, close it, lock it, etc and no need to do anything unusual. So if I'm by myself, no problem using the fob only. If I am out with the wifey, then I have to hand lock the passenger door first then hit the lock button on the key fob to lock the driver door.
So...looks like the passenger side lock needs to be replaced or reprogrammed.
Old Jul 30, 2011 | 02:35 PM
Correct, it is opposite but I think for the same fundamental cause. It is a combination of software/hardware that seems to plague the aston door locking issue.
Hopefully replacement/reprogramming will solve the problem.
Old Aug 12, 2011 | 08:52 AM
duo's Avatar
duo
duo is infamous around these parts
have you guys tried to turn auto door lock off?it works on my v8
Old Aug 12, 2011 | 09:02 AM
Tahoe M3's Avatar
I did that, and it worked for a while...then stopped working again.
Old Aug 12, 2011 | 10:24 AM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
My Remote works for the Doors--both Lock/Unlock, but doesn't work for the Trunk release. I've tried both Key Fobs with the same result. Dealer will check it out next week and I'll let you know.
Old Aug 12, 2011 | 10:33 AM
Racer_X's Avatar
You do realize that it takes two presses to release the trunk, right?
Regardless, my trunk release is poor. It works, but I normally need to press the button three or more times before it works. I also need to be sure that I hold the fob up in the air when I am directly behind the car for the button presses to register.
Old Aug 12, 2011 | 10:58 AM
karlfranz's Avatar
I have an appointment to bring my V8V to the dealer for some warranty work a week from tomorrow. The problem with the door locks is one of the issues they will be looking at. In my case, the key fob arms the alarm and flashes the lights, but doesn't always lock the door. If you try to open the door the alarm will be triggered. The dealer said he was familiar with this issue and has seen it on other cars.
I have also noticed that the inside console switch for the trunk doesn't always work. I have to unlock the doors first with the other switch before the trunk switch will do anything. The dealer says this is normal behavior but this doesn't seem right to me. The same thing happens when I use the key fob. I have to unlock the doors first then I can press the trunk button twice to open the trunk.
Old Aug 12, 2011 | 11:54 AM
RPVantage's Avatar
RPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to beholdRPVantage is a splendid one to behold
the way i do it is. before i take the key from the ignition i open my door and then lock the car from the inside, then if i lock with the remote everything is fine.
Old Aug 12, 2011 | 06:38 PM
Kamran's Avatar
Kamran is just really niceKamran is just really niceKamran is just really niceKamran is just really nice
I had this problem and took it to the dealer. They changed the unit in the driver door and the problem went away. 3 months later, the problem was back and I took it back to the dealer. This time they changed the same unit in the passenger door (and the service manager acknowledged that vantage is known for this plague). It's been 18 months now since the last repair and everything works just fine (knock on the wood).
Old Aug 1, 2012 | 10:34 AM
Malibu101481's Avatar
Malibu101481 is infamous around these parts
Just discovered my car has this wonderful problem.
Anyone know the ballpark $$ to fix?
The_Orange
Oct 3, 2015 08:23 AM
BarrettG
Sep 30, 2015 02:46 PM
TOGWT
Detailing
Sep 28, 2015 08:25 AM
