Rapide "plastic key" battery replacement
Old Dec 28, 2012 | 03:07 PM
gircal's Avatar
gircal is infamous around these parts
Does anyone know how to do this and what size battery it takes. Thanks...
Old Dec 29, 2012 | 03:25 PM
62Jeff's Avatar
62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !
I would trust the procedure is covered in your owner's manual.
The battery in my DB9's fob is a typical CR2032, used in many automotive remote key fob applications.
Old Dec 29, 2012 | 11:18 PM
gircal's Avatar
No, there are no instructions as to how or where to begin to pry it open, so I'll figure it out. And, it is probably is the 2032 ... as are many others. Thanks.
Old Dec 30, 2012 | 08:17 AM
62Jeff's Avatar
That's odd. I'll check the manual in my DB9 to see if there's something in mine, and if so I'll post it for you in case it is the same as the Rapide. I only assume, but do not know, the keys would be the same.
Old Dec 30, 2012 | 08:46 AM
62Jeff's Avatar
I couldn't find instructions in my manual either, so I took my plastic key apart and documented it in hopes it applies to your Rapide.
1) Turn the key over with the small hole facing up
2) Insert a small pin into the hole and push. The end cap should come off
3) The end cap has a directional clip on the end, make sure to put it back on the same way
4) With the end cap off, a slot is visible
5) Insert a screwdriver into the slot and twist in order to pry the 2 halves apart.
6) And here's the battery.
7) Assembly is simple, snap the 2 halves back together and then snap on the end cap.
Old Dec 30, 2012 | 08:48 AM
gircal's Avatar
Thanks, Jeff, I also assume they would be similar. I appreciate your posts.
Old Dec 30, 2012 | 09:04 AM
gircal's Avatar
And, indeed they are the same. Many thanks, Jeff, for your most descriptive posts and enjoy that beautiful "Sage Green" DB9!
Old Dec 30, 2012 | 09:06 AM
62Jeff's Avatar
Cool, good to know they are the same. I'll create a how-to thread to make it easier for future owners needing to replace their batteries.
Jul 29, 2019 11:13 AM
DetomasoGTS74
Nov 11, 2015 09:01 AM
OldBoldPilot
Aug 24, 2015 04:00 PM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
DSCOFF
Aug 23, 2015 01:22 PM
