The grill work in the hood/bonnet of the DBS...
Old Apr 7, 2014 | 04:26 AM
rscultho's Avatar
rscultho is infamous around these parts
So, the grill work in the hood/bonnet of my DBS is somewhat "basic". The color of the grill work is a battleship gray. They are functional of course, but one would think this could be dressed up a bit from what it looks like. In fact, the car I purchased stickered at $264K when new. One would think that for that price, you would get something a bit more than just stamped wire.
Does anyone know if there exists an upgrade for these wire grills that keeps them functional? I have considered painting them with high heat paint, either Black or maybe Bronze? I bought some high heat Bronze paint some time ago and never used it. I wonder what that would look like?
Also, I am experiencing air coming through the portion of the door where the side view mirror attaches. Anyone ever had to have this fixed on their car? I am going to have it repaired under warranty...just wondered if anyone has had this issue.
Thanks for the feedback.
Old Apr 7, 2014 | 08:05 AM
4pipes's Avatar
4pipes is infamous around these parts4pipes is infamous around these parts
No air movement inside where outside mirrors attach in my 2010 DBS. Only "draft" is from left hand ac vent.
Old Apr 7, 2014 | 11:09 AM
rscultho's Avatar
4pipes...how loud is your exhaust (inside the cabin, windows rolled up) when you are cruising? Does the loudness interfere at all with the radio "volume"?
I know that's a difficult question to answer. And, maybe I am just not completely used to mine as yet, but my exhaust is LOUD inside the cabin. Even when I am cruising, I cannot hear the radio "completely".
My XKR was virtually silent while cruising. I don't expect the DBS to be as quiet, but what I am experiencing is above what I expected.
Old Apr 7, 2014 | 11:26 AM
4pipes's Avatar
I have the exhaust valve fuse pulled on my DBS. I prefer the sound of the car to the crap B&O sound system, the one in my BMW and MBZ are much better. You need to see if the previous owner pulled fuse 22 (I thinks that's the one). If so, replace it and the car will be MUCH quieter while cruising. The valve only opens at higher rpms.
Old Apr 7, 2014 | 01:18 PM
XJRS Owner's Avatar
Reading all the Fuse 22 stuff, I pulled mine. Couldn't stand cruising with it open all the time, so put the fuse back in.
Old Apr 7, 2014 | 02:01 PM
rscultho's Avatar
Mine is still apparently in...I will check to see if the vacuum lines are plugged...cause if it is this loud with the fuse still in, if would be deafening if it is louder with it out!!
Old Apr 7, 2014 | 04:52 PM
4pipes's Avatar
Good idea. My fuse is still in but I had the service tech plug the vacuum lines so no codes would be thrown.
Old Apr 7, 2014 | 04:53 PM
4pipes's Avatar
BTW, my wife loves the sound, especially with the windows down.
Old Apr 7, 2014 | 10:10 PM
mfrankel's Avatar
mfrankel is infamous around these parts
A metal plating shop should be able to cheaply clean & "dip" your vent mesh in any metallic. Titanium color would be nice...or gold!
Old Apr 8, 2014 | 03:51 AM
rscultho's Avatar
So then I would have Gold grills to match my GOLD GRILL?!!
nlakind
Nov 6, 2015 10:15 AM
Qu4ttro
Cayenne 958
11
Sep 4, 2015 01:35 PM
riverflyer
Sep 1, 2015 04:22 PM
