ABS / DSC Warnings - limp mode? 2007 V8V ASM
Old May 12, 2014 | 12:54 PM
dmose's Avatar
dmose is infamous around these parts
Greetings,
My 2007 V8V was softly hit a few weeks back on the front right side in a parking garage. There is very minor damage to the front right fender (slight bending, very slight) and cracked the side marker. The Headlight case etc is all in tact... for the most part everything else is fine.
I've been driving the car since that for a few weeks, then recently my car started to exhibit some strange behavior and I'm wondering if it could be electrical or something else?
-I started the car one night and the radio would not turn on... after stopping/restarted everything was fine. This is the first time I've ever seen the car do this.
-I slipped the DSC doing a hard turn slightly and then I got a Christmas tree (see image)
ABS / DSC lights come on with a warning "traction control turned off". In this mode, the car does not downshift in sport mode (ASM) ... and it won't go into reverse! Is this the car in "limp mode" ?
I found that hitting the battery reset switch got rid of the DSC warning...which takes the car out of limp mode, but ABS light stays on. After 10 starts, everything goes away.
I then did another "hard turn" and slipped the rear wheels a bit... and again, Christmas lights all over and limp mode.... Anyone else have something similar happen? Honestly the lights don't bother me..its the retarded No-Reverse that absolutely drives me crazy.
I have the car at the dealership waiting for a scan but wanted to be proactive.
FUSE22 has been removed for over a year
http://imgur.com/RSyZna1
Old May 12, 2014 | 01:31 PM
karlfranz's Avatar
Sounds more like your battery is dead than anything to do with your fender bender.
Old May 12, 2014 | 03:08 PM
Vergis's Avatar
Vergis has a spectacular aura aboutVergis has a spectacular aura aboutVergis has a spectacular aura about
I had a similar problem. Check your abs wheel sensors. It can give off x mas tree lights as well.
Old May 12, 2014 | 03:17 PM
dmose's Avatar
Did you have the same no downshift/no reverse issue as well??
Old May 12, 2014 | 03:19 PM
Vergis's Avatar
Mine is a manual. However I have heard of there being an ecu or similiar located behind the fender that can effect the electronics. But I am not sure if it was the ecu for the roof mechanism. Is your car a soft top ?
Karl could be right. It could be the battery.
Old May 12, 2014 | 06:12 PM
bluebarchetta's Avatar
bluebarchetta is a glorious beacon of lightbluebarchetta is a glorious beacon of lightbluebarchetta is a glorious beacon of lightbluebarchetta is a glorious beacon of lightbluebarchetta is a glorious beacon of lightbluebarchetta is a glorious beacon of light
Having just installed carbon side strakes, and painted the mesh's; I can confirm there is an ECU in the front right fender. We had to loosen and move it slightly to get access to the strakes/mesh.
It's possible something in this area was loosened by the contact. Not saying this is the case, just maybe possible
Old Jun 13, 2014 | 09:05 AM
dmose's Avatar
Just an update .. replaced the battery and magically all negative electrical symptoms vanished I would high recommend it to anyone still on their original for older model V8's
Old Jun 13, 2014 | 09:38 AM
karlfranz's Avatar
First recommendation I always tell people when they start having extremely odd electrical behavior. Glad it worked for you.
the5
Oct 14, 2015 06:46 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
oo7
Sep 10, 2015 08:08 AM
carsnob
Sep 8, 2015 04:10 PM
DetomasoGTS74
Sep 7, 2015 09:42 AM
