Engine making ticking noise.
Old Aug 2, 2018 | 10:38 AM
  #61
Cressell's Avatar
Cressell is infamous around these parts
Hi!
Sorry about the necro, but I'm curious about an update to this?
Old Aug 2, 2018 | 10:52 AM
  #62
theegolden1's Avatar
theegolden1 is infamous around these parts
Originally Posted by Cressell
Hi!
Status is still pretty much the same. It's been 100+ weather out here for the last couple of weeks, so the ticking starts up within an hour of driving. When it starts ticking, I just drive it home so I won't be embarrassed by the noise. 80 degree and below weather I can drive for quite a while with little to no ticking. The increase in outside temps most definitely has an affect on it, which is mind boggling to me.
Old Mar 17, 2019 | 06:38 AM
  #63
ryanr317's Avatar
ryanr317 is infamous around these parts
I recently purchased a 2005 DB9 and i'm having what seems to be the same issue. My ticking is not as loud though. How many miles have you put on the car since you discovered the ticking?
Has anyone else found a resolution to this other than the engine rebuild?
Old Mar 18, 2019 | 12:47 PM
  #64
embdenb's Avatar
Not sure about an engine rebuild. Ticking has to be in the valve train. There in no way that Aston is not aware of this and what the solution is.
Old Mar 18, 2019 | 03:43 PM
  #65
​​​​​​I put on another 1000-3000 miles on it since the ticking started.
Old Mar 18, 2019 | 03:46 PM
  #66
They most definitely know about it. And I bet it would be a pretty expensive fix on their behalf if they put out a recall on it. But it's not causing physical harm to anybody so they just sweep this under the rug. Smh.
Old Mar 18, 2019 | 04:23 PM
  #67
ryanr317's Avatar
I've included a video where the sound can be heard. Mine also only ticks when it reaches and stays at operating temperature for a bit. I remember MaverickV12 saying that he changed his thermostat to the Vanquish one which results in the engine running cooler. Has anyone else tried this? I'm wondering if a cooler running engine will help since it seems the tick only occurs when the car is hot. Mine is a 2005 and has the updated dipstick but i'm not sure when that update occurred and if it was ever run low on oil. Unfortunately, it didn't tick during test drive and I neglected to have a PPI done. This will be a weekend car and I'm wondering how long I should/can keep on driving it before having it stripped. It seems that folks with the tick have lived with it for years.
Old Mar 18, 2019 | 04:57 PM
  #68
XJRS Owner's Avatar
Supposedly piston slap in ovalized cylinder liners. Caused by piston big end bearings allowing piston to move too much in the bore. Rumor was that AM changed these to a 'better' bearing thus eliminating the root cause. But take all this with a grain of salt.
Old Mar 23, 2019 | 06:16 AM
  #69
ryanr317's Avatar
UPDATE
So I started thinking about MaverickV12's statement about the car overheating. The last few months I have been driving the car from time to time. I normally wouldn't drive it in weather that is cold enough for me to not drop the top but I've driven it anyways. And I've noticed that when the weather is less than 65 degrees F, that the car never ticks or takes a really long time (maybe hours) before it starts ticking. Weather above 65 degrees F, the tick comes faster (90+ F, tick will start within 15-20 mins).
So I took MaverickV12s advice and looked into the possible overheating. I ordered a new thermostat and I just removed the radiator. Took the radiator to a radiator shop nearby and they did a quick pressure test..........30% clogged.
So I'm not sure how bad 30% clogged equates to or even if the outside temp truly affects engine temp. But it's a start to some troubleshooting.
I will keep y'all posted.......
And a special thanks to MaverickV12 for chiming in on this.
I'm assuming a flushed/new radiator and new thermostat didn't help? Maverick had mentioned that he replaced his thermostat with the one from the Vanquish, which appears to be the same part number as the one used in the 2013+ DB9. This supposedly opens 10 degrees celsius cooler. Is this the one you ordered? It seems that I may have to, at some point, break down and have the engine rebuilt if it is the bottom end issue. I'm just thinking that since the tick doesn't start until the engine becomes heat soaked, that perhaps it running cooler would stop the tick.
Old Mar 23, 2019 | 09:21 AM
  #70
XJRS Owner's Avatar
Maverick solved his problem by having the engine rebuilt by B&R. New rod bearings, piston rings, cylinder liners. Don't know if the pistons were changed, but indications are they were still good.
Old Mar 24, 2019 | 03:28 PM
  #71
Ray F's Avatar
5 Year Member
Ray F is infamous around these parts
I had a late DB7VV that also did this; never did get to the bottom of it, but I did get to silence it. I modified the water valve so it was permanently open and also altered the temp points at which the fans came on - bottom line was: keep the engine cool.
I've heard that as well as the DB7 V12, the issue afflicts the DB9 V12s that were made pre-Cologne manufacture (I've also personally heard it on a couple of early Vanquish's). As I understand it, you can tell if it's a Cologne engine if the number starts with a 1; Cosworth engines start with a 0. I would be interested to know if those on here who have the tick noise have an engine number beginning with 0 or 1?
Old Mar 26, 2019 | 09:30 PM
  #72
V12Stealth's Avatar
5 Year Member
V12Stealth
Originally Posted by dan87951
What about the 100k mile DB9 that was on eBay not to long ago? Did he get lucky as well? I know it sucks to be the unlucky one with a bad DB9 engine but spreading propaganda that all DB9's will suffer the same fate is just not accurate.
From all this reading, it sounds like it has nothing to do with luck. Its simply a factor of time.
If what is being said about the small end rod bearings of early cars wearing out due to inadequate oiling due to a "design flaw" of the shells and/or hot spots in certain areas of the engine is true, then this will happen to everyone who drives the car hard. Cruising on a highway and racking up the miles will simply result in the car having higher mileage before the symptoms begin to show.
I see this as analogous to clutch life for example. You drive in stop-n-go traffic, you'll get less miles out of it compared to someone who is mostly driving on the highway.
All one can do is just avoid the pre 2008 cars altogether or do a PPI and hope your driving style and weather gives you enough engine life for your ownership.
Just my $0.02.
Old Apr 29, 2019 | 02:19 PM
  #73
ryanr317's Avatar
How were you able to alter the temperature at which the fans come on?
Old May 2, 2019 | 04:19 PM
  #74
Ray F's Avatar
5 Year Member
Changed the fan settings so that the one that normally comes on first, at about 90deg, came on with ignition and the other (high speed) fan came on at 90 instead of the higher temp. This second one also comes on when the AC compressor is running. I didn't do the work, just got a local car electrical expert to do the work.
Old Nov 26, 2019 | 05:38 AM
  #75
ryanr317's Avatar
I reached out to Aston Martin just via their contact form on their website. Based on this, I guess my next step is to pay the dealership to tell me I need an engine rebuild or tell me to run a thicker oil. Below is the unsurprising response:
"Firstly, on behalf of Aston Martin, I apologise that you are experiencing a reported concern with your DB9 V12.
As I am sure you can appreciate, your Aston Martin is outside of its Manufactures Warranty, but in the first instance I would recommend that your car is looked at by an Aston Martin Approved Dealership so they can advise you further on your reported concern."
