Those of you with CPO / Third Party Warranties... use them much?
Old Jul 18, 2014 | 07:48 PM
  #46
bluebarchetta's Avatar
bluebarchetta is a glorious beacon of lightbluebarchetta is a glorious beacon of lightbluebarchetta is a glorious beacon of lightbluebarchetta is a glorious beacon of lightbluebarchetta is a glorious beacon of lightbluebarchetta is a glorious beacon of light
Originally Posted by midwestamv8
Ugh. I'm thinking I just have to wait for a CPO car just to put my mind at ease....
I hope nothing I said about the warranty/demo, put you off the 2013. I just wanted to put you at ease that it was likely not a car owned by anyone, and you'd be essentially the first owner. If its a demo, it would not have been titled. I bought my first S2000 that way and saved a lot, ended up with a great car for 6 years.
However, if you really want a different color, then by all means wait. It took me a good 6 months to find a car with the color and specs I wanted.
Old Jul 18, 2014 | 07:51 PM
  #47
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Just what you want?
Ugh. I'm thinking I just have to wait for a CPO car just to put my mind at ease. I have a feeling all these third party cars will just fail inspection after inspection and I'll dump a ton of money and get nowhere...
Come on AM dealerships! Just pick up ONE used meteorite silver in 6spd w/ black interior and contrast stitch and I'm yours...
Here's a new listing at Los Gatos AM exactly like you asked for (with a new set of tires too!), and one year left on the factory warranty:
http://www.losgatosluxcars.com/Certi...CA/vd/19560264
Check your PM's too .
Old Jul 18, 2014 | 09:14 PM
  #48
midwestamv8's Avatar
midwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud of
Originally Posted by karlfranz
Just to be clear, it is perfectly fine to have different brands or models of tires on a car as long as the tires on each axle match.
Here's an example:
The rear tires on my 07 V8V wore out but the fronts still had about 50% tread left. I didn't want to buy another set of the OEM Bridgestone Potenzas because, frankly, they are crap. They are rated #27 on Tire Rack. I wanted to go with the best possible tire for the car so I put on a rear set of the #1 rated tire: the Michelin Pilot Super Sport (I also increased the cross-section width by 10mm). I drove with a mismatched set until the front OEM tires finally wore out and then replaced them with the Michelins.
Thanks for setting me straight. It's obvious I have a lot to learn about these cars. I just remember from my days of owning an s2000 that the potenza's were some of the best tires around. I suppose I need to realize that was quite some time ago and a completely different car. I saw a car for sale in NJ on Michelin's and I immediately discounted it thinking the previous owner cheaped out and didn't spring for the potenza's. Now I know!
I can understand where you were coming from on the tire swap. I had just always heard that having two different brands with different tread characteristics and different wear (especially on a sports car, front and back) was a recipe for bad things. I suppose it would be because of a mis-match in balance or grip or water shedding, but at this point I'll say it's hearsay and I don't remember where I heard it from. I'm sure 99% of people have had no problems with it. And I suppose it makes a lot more sense than always replacing the fronts when the rears go
SlinginHoss
11
Oct 8, 2025 05:16 PM
speedsterr
Oct 26, 2015 09:18 AM
MeddlingKid
Oct 20, 2015 07:43 AM
