Rear Pads Low
Old Aug 12, 2014 | 12:22 PM
flittlejr's Avatar
flittlejr is infamous around these parts
Question Rear Pads Low
Lady backed into my 06 db9. Body shop drove out to end of building detailed including tire shine. When started the "rear pads low" info was on and red brake lite on dash was on. We figure tire shine got on rotors? Light goes out when you mash on brakes to stop, only on when @ stand still? Any ideas? Thank You
Old Aug 12, 2014 | 12:47 PM
karlfranz's Avatar
Might have dislodged one of the pad wear sensors.
Old Aug 12, 2014 | 01:19 PM
flittlejr's Avatar
Smile Pads Low
Thanks. They may haver used pressure washer
Old Aug 12, 2014 | 02:09 PM
J doubleU's Avatar
Your rear brake pads are worn out, or the lip of the worn brake rotor has cut into the sensor. If you mash on the brakes it goes out? Clear sign of sensor open circuit. You are making the open circuit closed by touching the rotor with the worn sensor.
Old Aug 12, 2014 | 04:28 PM
flittlejr's Avatar
Thumbs up Low Pad Lite
The Body shop that did repairs is Rick Hendrick Collision Center so when the lite came on after detailing they pulled rear wheels and both brake pads (75%) and e-brake pads close to 100% (never use). So I don't know if the sensor dislodged when the detailed, wonder if it is on the back of rotor where they would't notice? Thanks for the reply
Old Aug 14, 2014 | 08:38 AM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
Yes the sensor is behind the rotor, it sits in a little slot in the inside brake pad so it would be hard to see. Just removing/replacing the wheel would not dislodge the sensor.
Old Aug 14, 2014 | 02:41 PM
flittlejr's Avatar
Smile Rear Pads Low
Finally got in to see my 15 year european mechanic, and he said pads were down to 3/32nds barely above state inspection. The regular shop was measuring pad and backing to get 7/32nds reading. Now to search the web for best rear pads. Thanks for all the replies
Old Aug 14, 2014 | 06:51 PM
zvez's Avatar
zvez is just really nicezvez is just really nicezvez is just really nicezvez is just really nice
carbotech seem to be very popular here.
Old Aug 16, 2014 | 10:23 PM
stevev201's Avatar
stevev201 is infamous around these parts
Rear brake pads
Id Vote for Porterfields! So far I have had good luck and no noise!
Old Aug 17, 2014 | 05:51 AM
flittlejr's Avatar
Rear Pads Low
Thanks, I'll order tomorrow. Frank
Old Aug 17, 2014 | 05:05 PM
flittlejr's Avatar
Porterfield is what I'm going with but they don't have sensors. Best place to buy? Thanks Frank
Old Aug 17, 2014 | 06:01 PM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
The Porterfield R4-S pads do have the slots for the sensors, but they are not mirror image pads. Do a forum search for more detailed information.
You can replace both the front and the rears for the same or less cost than buying the factory Pagit pads.
I would recommend that you do both axle sets at the same time-
I purchased my pads from topbrakes dot com, free shipping and about a 10% discount from list price.
Same pads are available for your year DB9, according to the site.
Stewart may have a deal also?
Old Aug 18, 2014 | 04:47 AM
dan87951's Avatar
dan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to all
I love my ceramic EBC reds once I got the squeal issue resolved. However, make sure you install the anti squeal shims from Aston Martin (4G43-28-10789) if you plan on running EBC brake pads. Also, the brake dust with the reds is pretty much halved when compared to the factory pads which is a nice perk.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
gulf gt
Aug 27, 2015 10:27 AM
rnl
Aug 26, 2015 02:36 PM
awchristler
Bentley
Aug 24, 2015 03:53 PM
