V8V Trunk Gap?
Old Mar 19, 2015 | 09:36 PM
Townshend's Avatar
Townshend is infamous around these parts
V8V Trunk Gap?
One thing I've noticed and have wondered about is the gap between the rear lights and the trunk seems to be off a bit as they are not completely flush. Everything aligns properly and there are no other issues. Normal?
Old Mar 20, 2015 | 08:03 PM
TGED's Avatar
TGED is infamous around these parts
What about the other side?
Old Mar 20, 2015 | 08:43 PM
spf1410's Avatar
spf1410 has a spectacular aura aboutspf1410 has a spectacular aura about
Here is a photo of mine I took last summer. Nearly the same angle.
Old Mar 21, 2015 | 12:25 AM
Townshend's Avatar
spf thank you for the shot. Your angle is the same as mine where it is flush there, I'm referring more to these angles. Here are both sides. Everything fits properly and seems to all align correctly.
ID:	416761   Click image for larger version
Old Mar 21, 2015 | 10:18 AM
midwestamv8's Avatar
midwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud ofmidwestamv8 has much to be proud of
Your tail lights are out of adjustment is all. There are three bolts on the rear of each light. Remove the inner trunk lining, loosen the bolts for each light slightly, adjust the lights so they match up with the body lines, and re-tighten. There are rubber seals that are supposed to be replaced if you remove the lights, but they may be okay if you just adjust them slightly. If you get leaking after the adjustment you'll need to replace the seals.
EDIT: It also looks like you have condensation in your driver side ligt.
Old Mar 21, 2015 | 10:22 AM
Townshend's Avatar
This is great, thank you a ton for the suggestion. Yes, there is a little condensation on the driver side tail light, will have to check the rubber seals. My first tinkering with the car, looking forward to it actually. Thank you!
Old Mar 22, 2015 | 07:50 PM
Townshend's Avatar
A follow up, you nailed it. Easy fix. Thanks again!
Old Mar 22, 2015 | 09:03 PM
Glad I could help!
White991TT
Mar 8, 2016 06:01 AM
Glasgo
Nov 30, 2015 02:37 PM
sdg1871
Nov 22, 2015 07:27 PM
Sales@RSW
Lamborghini
Oct 1, 2015 02:01 PM
jdubbya
Sep 28, 2015 04:58 PM
