Installing Radar Detector below Mirror
Old Feb 16, 2016 | 02:02 PM
embdenb's Avatar
As some might remember I have been working with a company to create a mirror mount for a radar detector for the Aston Martin Vantage.
I have completed the process and we have developed a mirror mount specifically for the Vantage.
If the mirror stems are the same I am sure this will fit other Aston Martins as well.
For those interested I have documented the process on my website at:
http://bernardembden.com/am/detector/index.htm
Old Feb 16, 2016 | 08:17 PM
ncamv8's Avatar
ncamv8 is a name known to allncamv8 is a name known to allncamv8 is a name known to allncamv8 is a name known to allncamv8 is a name known to allncamv8 is a name known to all
Nice Write up, good detail and pictures.
Old Feb 16, 2016 | 09:06 PM
Montana107's Avatar
Montana107 is infamous around these parts
Thank you for sharing!
Old Feb 16, 2016 | 09:36 PM
Kent's Avatar
Kent is infamous around these parts
Excellent
Old Feb 17, 2016 | 10:26 AM
RolexDaytona1's Avatar
RolexDaytona1 has a spectacular aura aboutRolexDaytona1 has a spectacular aura aboutRolexDaytona1 has a spectacular aura about
That's a perfect install and great write-up for a Valentine One !
For others... keep in mind though if you go with the passport instead.. it has GPS and needs a view of the sky. I had to keep mine on the windshield so the top had a sky view.
Thanks for posting!
Old Feb 19, 2016 | 07:12 AM
Gene G's Avatar
Gene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond repute
Great job. Thanks for posting the process and pictures.
Old Jan 26, 2025 | 09:23 AM
momo stallion's Avatar
momo stallion is infamous around these parts
8 years later, thanks for this great write up with nice pictures and still hosting the instructions!
Old Jan 26, 2025 | 10:39 AM
Jay_Davis's Avatar
Jay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud ofJay_Davis has much to be proud of
Hey don't make fun, I can understand why someone would convince themselves it is still 2016.
Old Jan 26, 2025 | 10:51 AM
embdenb's Avatar
You are welcome. Glad that I could help.
Old Jan 28, 2025 | 02:46 PM
embdenb's Avatar
Apologize, I cannot find the name of the person who sent me a private message saying that Blend Mount does not have a listing for the 2007 Vantage. The person went on to say that they called Blend Mount and they have no record or part number of a Blend-Mount system that I co-designed with them for my 2007 Vantage from April through July 2020.
Because that design and installation was documented on my website the person wanted to know if I could provide them with any pertinent information about what parts to order.
Below then is the information that I have.
The person at Blend Mount that I dealt with was Colin from customer service. Phone number 888-497-8388
The part number is BV1-2021 and I used power tap part number MT-1015.
There is a possibility that BV1-2021 was the starting point and the end result was a modification of BV1-2021. I do know that we exchanged multiple mount and parts to finalize the finished product.
A search of the Blend-Mount website does show a mount for the 2007 Vantage. Its part number BV1-2029 (pic below)
Hope this helps.
Old Jan 28, 2025 | 02:53 PM
embdenb's Avatar
One final point. If your mirror is Home Link capable and has automatic dimming, a small part of the Blend Mount holder that we designed will block the mirror's sensor.
Rather than sent it back to Blend Mount I removed that part of the mount to clear the sensor. (The mount is aluminum and not difficult to modify)
Old May 24, 2025 | 05:02 PM
tragicallyhip's Avatar
tragicallyhip has a spectacular aura abouttragicallyhip has a spectacular aura abouttragicallyhip has a spectacular aura about
@embdenb Thanks for your write up. I hardwired my Uniden R8 to the mirror with that as a reference. I found that the none of the 3 different styles of mirror tap cable prongs were able to fit in behind the wiring harness. Either they were too big or were too loose after I shaved down the prongs trying to get them sandwiched next to the existing harness wires. So, I ended up stripping the mirror wires and soldering inside the car. In my 2016, it seemed impossible to remove the wire harness and solder at the work bench, which would have been much much easier. After soldering, I taped and zip-tied for protection. One thing I was initially going to try was wiring the radar detector to the passenger map light so I could turn it on and off with the console button, but the map light only registered 7.5 volts and was not enough to power the detector. If I remember correctly, the mirror was putting out around 11.25 volts and works like a charm. The only insignificant/odd thing is that the mirror apparently turns off in reverse, so the detector briefly shuts off when backing up.
Old May 24, 2025 | 08:27 PM
ragingfool35's Avatar
ragingfool35 is infamous around these parts
there is always this:
https://www.6speedonline.com/forums/...t-project.html
my 2009 came with a 9500 Ci installed
996-Sam
Aug 19, 2016 02:09 PM
jpahad
Apr 16, 2016 08:00 PM
996_911C2_Dhru
Feb 19, 2016 10:13 AM
King James
Feb 19, 2016 09:38 AM
