Is there anyway to raise the seat in V8?
Old May 18, 2016 | 04:28 PM
rhart6's Avatar
5 Year Member
rhart6 is infamous around these parts
Despite the fact I'm 6-1 I would like a little more height on the seat bottom so I can at least come a bit closer to seeing my front corners. Something we racers seem to like. Has anyone raised the driver seat in a 4.7? I can't be the only one that feels it is too low. Most cars across the pond go forward and back on an angle so you can raise or lower the entire seat. The AM only travels in what is close to a line parallel to the ground so I wish it had a up and down button. I have the memory seats.
Thanks in advance
Old May 18, 2016 | 04:51 PM
telum01's Avatar
Add spacers between the floor and the rails, bolt the seat back in with longer bolts to account for the spacers. Can do it in 20 minutes if you've got the spacers and bolts ready to go.
Old May 18, 2016 | 05:42 PM
Mathman85's Avatar
Mathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to all
... it does have an up and down button. Press the lower button upwards and the seat will go up (unless it's already maxed, of course).
Old May 18, 2016 | 05:44 PM
rhart6's Avatar
5 Year Member
Is it as easy as it sounds? Can I use a larger size nut for the spacer?
Old May 18, 2016 | 05:53 PM
telum01's Avatar
Yeah, I thought it was pretty easy to pull the seat out completely (hardest part was unplugging the various wiring harness connectors). You don't have to pull it out or disconnect anything - just pull the bolts, tilt the seat, put a spacer in, set the seat back down, use a longer bolt to refasten it.
I wouldn't use an over-sized nut for it due to safety concerns.
Old May 18, 2016 | 08:17 PM
rhart6's Avatar
5 Year Member
Ha. I started to write you that I have that button but it doesn't do up and down. Before writing this I went out and thought I would try it one more time. It was just now that I discovered a little trick. If you take one finger and push up or down it seems to trigger back and forth. BUT if you take two fingers and put one on each end of the rather long button and push up or down with both fingers it triggers the desired up and down. This missive may help others or make me look real stupid. Or both.
Old May 18, 2016 | 08:31 PM
Mathman85's Avatar
I'm 5'7. If I hadn't figured that out, I probably wouldn't be able to drive the car. LOL
Did that get you the height you needed?
Old May 18, 2016 | 08:54 PM
shootermcgav1n's Avatar
shootermcgav1n has a spectacular aura aboutshootermcgav1n has a spectacular aura about
I was about to say I'm the same height and have test driven a couple, both of which I had been able to raise the seat on.
Old May 18, 2016 | 09:00 PM
rhart6's Avatar
5 Year Member
I had an 08 V8 that was never a problem. I guess oldfartedness has set in. Driving position is now comfy. I'm mainly a Porsche guy and am used to seeing the front corners which will never happen in the AM. The trade off for that beautiful contour and the sorta mid engine neutral handling is well worth it.
Old May 18, 2016 | 09:16 PM
Zettinger's Avatar
Zettinger is a glorious beacon of lightZettinger is a glorious beacon of lightZettinger is a glorious beacon of lightZettinger is a glorious beacon of lightZettinger is a glorious beacon of light
Thank god. I already pictured you at 6.1ft with 4ft legs in a recliner seat.
Old May 18, 2016 | 09:50 PM
rhart6's Avatar
5 Year Member
Hey its not funny trying to buy jeans with a waist size of 34 and inseam of 26. Easier however than trying to drive my 6 speed V8 with those big wood extension blocks on the pedals.
Old May 19, 2016 | 06:11 AM
mkzhang's Avatar
mkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud of
Man I was about to say, I'm 5'5 and compare to you, I'm probably not even visible to the people outside the car when I'm behind the wheel lol
Old May 19, 2016 | 08:11 AM
lol short ppl problems, the struggle is definitely real.
rhart6's Avatar
5 Year Member
Did anyone ever notice the notch in the forward center portion of the roof? It is a knock out panel for the factory option periscope for buyers under 6'5".
Old May 19, 2016 | 09:27 PM
ncamv8's Avatar
ncamv8 is a name known to allncamv8 is a name known to allncamv8 is a name known to allncamv8 is a name known to allncamv8 is a name known to allncamv8 is a name known to all
I always thought that was the ejector seat option
GT650-25
Apr 18, 2016 09:51 AM
msgm1
Apr 13, 2016 12:13 PM
hollynitro
Apr 12, 2016 06:17 AM
Todd Gibbs
930 Turbo
Apr 9, 2016 03:27 PM
Wealth Manager
Apr 4, 2016 11:37 AM
