DB9 - Navigation unit removal
Old Oct 4, 2017 | 05:29 PM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
Anyone know how to remove the 3 rivets holding the nav bracket to the seat frame?
Old Oct 5, 2017 | 01:17 AM
GDay2's Avatar
GDay2 is a jewel in the roughGDay2 is a jewel in the roughGDay2 is a jewel in the rough
Drill out the rivets
Old Oct 5, 2017 | 12:04 PM
randyb's Avatar
Trying to avoid that
Old Oct 5, 2017 | 12:08 PM
randyb's Avatar
On a side note, the St.Pete Aston dealer Tech told me the ICM was the dash gauges and what was causing the radio to not work was a bad CRM. When I told him the ICM was in the center console, he told me oh, that is the RCM ( I was like WTF) and so I explained that if he checked with Aston, he would find out the ICM was in the CC and my CRM was just replaced. Then he told me my less then 1 year old battery was bad and my Multi Media player was most likely bad. I just told them to get my car back together and I would think about that.
So, do not go to Dimmitt for ANYTHING!!
Old Oct 5, 2017 | 01:11 PM
GDay2's Avatar
Hi Randy,
The only way to remove rivets is drilling them, well you might laser the head off as well but his is over the top
Why do you want to remove the nav bracket?
I pass on all 3 letter abreviated modules, what are you trying to fix?
Old Oct 5, 2017 | 02:04 PM
J doubleU's Avatar
You sure they are rivets, the navigation module is usually mounted by TORX head screws.
Old Oct 5, 2017 | 04:22 PM
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
Yep I agree, obviously the Tech had now clue to what he was talking about.
Contact Rich at REDPANTS, he took mine out completely so he will know. Also contact SdeKonig a member on here, he completely knows how to remove.
Old Oct 6, 2017 | 10:30 AM
randyb's Avatar
Yes, but they are weird, the seem to have a ring on the inside of the tip of the rivet that holds the rivet in place, I have never seen anything like it. Not sure why the did not use a nut and a bolt or torx screw.
Old Oct 6, 2017 | 11:38 AM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
Tamper proof Torx? Do you have a picture?
Old Oct 6, 2017 | 12:25 PM
W126C's Avatar
W126C is infamous around these parts
Have a set in my tool box, used them one time in ten years.
Regards,
Old Oct 6, 2017 | 04:29 PM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Might be what you need
Harbor Freight Item #68459
Includes nine Torx bits
Mine is still unopened...
Old Oct 7, 2017 | 08:19 AM
Old phart's Avatar
Old phart is a jewel in the roughOld phart is a jewel in the roughOld phart is a jewel in the roughOld phart is a jewel in the rough
The never ending tool escalation wars.
straight slot to phillips to allen to torx to ....
