V8vantage 4.3 heel/toe pedal problem
Old Mar 20, 2018 | 11:58 PM
ahtim's Avatar
ahtim is infamous around these parts
Hi guys, I have a stock 4.3 manual, and the gas pedal is actually too small or too short for me to do heel/toe, and the gap between brake and throttle pedal is too big; any one trying to change the actual pedals to solve this problem?
Old Mar 21, 2018 | 02:04 AM
TR-Spider's Avatar
5 Year Member
TR-Spider is infamous around these parts
One of the first things I did...I had a 12mm wide strip of 3mm thick aluminium welded to the left side of the throttle pedal.
Makes it look similar like the ones from another thead here (just without additional rubber spots):
https://www.6speedonline.com/forums/...-heel-toe.html
You need to remove the clearcoat to get a clean weld - afterwards some grinding/sandpaper workout...
Thomas
Old Mar 21, 2018 | 05:24 AM
ahtim's Avatar
Hi Thomas, thanks dude, do u have pics of your car’s pedal?
thanks
Old Mar 21, 2018 | 06:06 AM
Graze's Avatar
5 Year Member
Graze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to all
I have a custom made pedal for the V8V. Can't remember the name of the US company but if you pm me I'll dig it out
Works a treat
Graeme
Old Mar 21, 2018 | 06:17 AM
TR-Spider's Avatar
5 Year Member
here you go.
Old Mar 21, 2018 | 07:39 AM
ahtim's Avatar
Which should I do first? Flywheel and clutch? Or exhaust and ecu? Which make bigger difference, I don’t need the car to be super fast, I have faster cars, but I do want the throttle reponse to be faster
Old Mar 21, 2018 | 11:14 AM
ahtim's Avatar
Hi red pants, thanks for the info , if I am going to do the exhaust, do I need to do the header too? Or just the cat will do most of the job, and for the mid/x pipe, the stock is already a pipe without any muffler, do I still need to change it? coz I don’t want the car to drone during cruising, coz this is more likely to be one of my daily car.
Old Mar 21, 2018 | 11:23 AM
henryting's Avatar
henryting is infamous around these parts
You can change the throttle pedal by adding a side plate. However there are pros and cons : Unless you wear racing shoes which are quite narrow, adding a side plate will restrict your right foot when you wear normal shoes. I added one of these side plates and found out whenever I use normal shoes, when stepping on the brakes, there is a tendency to hit the throttle at the same time. First time this happened, it caught me by surprise because instead of slowing down the car by trail braking, the throttle action negates the braking action. Luckily I found out before getting into any mishaps.
Old Mar 21, 2018 | 12:02 PM
ahtim's Avatar
i will use some metal sheet like the Ferrari ones, and I will copy the brake/throttle gap from Porsche; and trim it to the size I want and put it on. I will even do the bottom right cut on the brake pedal just like the Ferraris. Once it’s done I will post pic
Old Mar 21, 2018 | 02:09 PM
smdzucladoc's Avatar
smdzucladoc is infamous around these parts
I got my thru ultimate pedal as it was recommend by other people here. You can have them do whatever size you like.
Old Mar 21, 2018 | 02:32 PM
rodg100's Avatar
rodg100 is infamous around these parts
I also have an Ultimate Pedal (Florida based company).
I actually installed this on top of my existing pedal to get some more height (you will need longer bolts)...works surprisingly well.
Old Mar 21, 2018 | 02:56 PM
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
I have the UP also, but have the same problem with it as henryting. I had just gotten the trick of the right angle to heel toe the original and the UP came in so I installed it. I've been meaning to take it out and go back to the stock pedal. Once you get used to the right angle of attack you don't need the wider pedal.
seattle_sun
Feb 26, 2022 11:00 AM
DD GT3 RD
Jun 28, 2010 10:25 PM
obsessed
Jul 29, 2009 09:19 AM
996TTs
Jan 31, 2009 07:10 PM
