Solution to your “quirky” Aston?
Old Aug 30, 2018 | 08:05 PM
MarcS's Avatar
MarcS is infamous around these parts
Plagued with problems on your 07 Vantage? The solution could be a super easy fix.
For several months I’ve been having problems pop up on my Aston including:
—Windows that sometimes wouldnt roll down or up.
—“Check engine” light with an emissions sensor message.
—Tire sensor warning
—Front left blinker sometimes wouldn’t work and would receive message of “Front bulb failure”. (That’s $2000 fix!!)
—Door would not unlock with the remote
—Wiper fluid wouldn’t work
—Cabin lights sometimes remained lit
—Seats occasionally not moving forward or backwards
—Wierd startup
—Many other problems.
Like the signal issue, some of the repairs were expected to cost MAJOR bucks. But another Vantage owner advised me to get my battery checked. Turns out the battery was no good. Bought another one, installed it myself and started it up. Every single one of those problems have been solved. Everything runs beautifully and works like it should.
So if you’re experiencing some quirks and other problems, get the battery checked before taking it in for repairs. A $200 battery sure beats a repair bill at the Aston dealership!
Cheers!
Old Aug 30, 2018 | 11:05 PM
shootermcgav1n's Avatar
shootermcgav1n has a spectacular aura aboutshootermcgav1n has a spectacular aura about
count your lucky stars. at least 4 of those are pretty standard problems.
Old Aug 31, 2018 | 06:10 AM
MarcS's Avatar
Definitely feeling relieved!
Old Aug 31, 2018 | 07:16 AM
superuser's Avatar
superuser is infamous around these parts
Our Land Rover LR3 gets very similar issues when the battery starts to go, must be similar 2006 Ford tech:-)
Old Aug 31, 2018 | 07:21 AM
MarcS's Avatar
Ha! Probably so. And if they designed the battery mounting brackets the same way in your LR3 as they did the Vantage, then I hope they slam their fingers in their car door! :-/
Old Aug 31, 2018 | 07:59 AM
XJRS Owner's Avatar
Use the battery tender whenever you park it, will keep you from having all sorts of nuisance problems.
Old Aug 31, 2018 | 07:45 PM
DonBond's Avatar
DonBond is just really niceDonBond is just really niceDonBond is just really niceDonBond is just really nice
True, very true......I own 15 of them......makes your batteries last a long time.
Old Aug 31, 2018 | 08:04 PM
MarcS's Avatar
How long of a period should it be parked before you start using the battery tender?
Old Aug 31, 2018 | 08:12 PM
DonBond's Avatar
Within a few days
Old Aug 31, 2018 | 08:14 PM
MarcS's Avatar
Within a few days
Thanks! Great advice. I’ll definitely start doing that when I park it for the week.
Old Aug 31, 2018 | 08:41 PM
DonBond's Avatar
Good deal.....it will save you a lot of grief
Old Aug 31, 2018 | 09:59 PM
XJRS Owner's Avatar
From the moment you pull into the garage. Unless I'm planning to drive it again within the hour, it's ALWAYS on the battery tender.
Old Sep 1, 2018 | 06:56 PM
jroback's Avatar
jroback is infamous around these parts
Let me add 1 more. . .
My CD changer stopped ejecting discs. It would stutter, but wouldn't spit the disc out. Sometimes when I turned the car off and restarted it the disc would finally eject, but then that stopped too. I replaced the battery, and the CD changer works perfectly again.
Maybe this list should be pinned ... nice to have an easily accessible list of signs that the battery is failing before it fails to start the car.
V12Vin
Jun 29, 2021 06:47 AM
wa1l1in
Feb 6, 2014 09:58 PM
Nick@Autogeek
Detailing
May 2, 2012 06:03 AM
