Homelink
Old Oct 22, 2018 | 01:22 PM
Jagman70's Avatar
Jagman70 is infamous around these parts
Homelink
The homelink transmitter in my 09 Vantage rearview mirror is not functioning. It's not a programming issue. I expect Aston utilized homelink equipped mirrors from some other brand like Jaguar, Volvo or Ford. Can anyone confirm this?
Old Oct 22, 2018 | 02:01 PM
J doubleU's Avatar
Any other faults? The mirror is a fused circuit thru the CEM along with other lamps. 5 amp fuse you may want to check.
Old Oct 22, 2018 | 07:23 PM
Jagman70's Avatar
JdoubleU, Thanks. No other faults. If you know, which fuse box? I have one in the boot, one under the passenger footwell and one in the engine compartment.
Old Oct 22, 2018 | 08:07 PM
J doubleU's Avatar
The CEM is the one at the passenger footwell. I think its F47 5 amp mini fuse. The diagram is in the owners book.
Old Oct 23, 2018 | 12:25 PM
MRCW's Avatar
Check too see if the mirror dims also. .. there's a wire/ plug in the overhead cover that could have for disconnected
Old Oct 23, 2018 | 03:04 PM
Jagman70's Avatar
I checked the fuse. It's ok and the interior lights also work. The mirror also dims at night. There is no indication that the Homelink is getting any power (or maybe it's just failed) given that he LED light does not turn on when I try the code cancellation procedure in the owner's manual.
I would like to see if it is getting power/properly plugged in. I'm not quite sure of the best way to remove the mirror. There is a cover containing the interior lights that somewhat surrounds the mirror base (This is a roadster). Does that cover snap off and allow access?
Old Oct 23, 2018 | 07:12 PM
J doubleU's Avatar
Sounds like the circuit and connection at the mirror are good. Time to go shopping for a new mirror.
Old Oct 24, 2018 | 04:41 AM
MRCW's Avatar
one t30 bolt removes mirror and then screw holds the cover on...
there's a plug inside to connect the power to the mirror.
Old Oct 24, 2018 | 06:50 AM
embdenb's Avatar
Check the archives. You can get the mirror repaired by a company that fixes these mirrors.
Old Oct 24, 2018 | 07:24 AM
J doubleU's Avatar
I don't think they are an approved vendor on here anymore.
Old Oct 25, 2018 | 12:00 PM
Jagman70's Avatar
I have been able to remove the mirror but do not see a way to open it. The only part that does not work is the Homelink. The auto-dimming feature works. The mirror is made by Magna Donnelly which supplies mirrors to a number of car manufacturers. My hope would be to find an inexpensive used (non-Aston) Magna mirror on e-bay that uses the same Homelink electronics and swap that in. However, there does not appear to be any screws that hold the the mirror case together. Is there a way to open it without damaging the case?
Old Oct 25, 2018 | 12:39 PM
J doubleU's Avatar
Homelink is the same for all manufactures, Its a fairly small unit I would guess they are all the same size.
Old Oct 25, 2018 | 03:04 PM
MRCW's Avatar
It can be very difficult. They're are a few YouTube videos about taking similar mirrors apart but not the Aston one. I tried but found it difficult...i was wanting to take it apart for different reason, as if added video rear view mirror to my V8V for my back up cam.
Old Oct 28, 2018 | 11:16 AM
Jagman70's Avatar
I found a place in Texas, Radar- Mirror.com who say they may be able to fix it but will need to examine the mirror to see if they have a Homelink board to fit. I hope to send it to them later this week given that the driving season is about over in the Northeast this year.
Old Oct 28, 2018 | 04:13 PM
MRCW's Avatar
ask for a price... you may be surprised their cos to crack it open and "fix" could be more than the cost of a new mirror...
i priced some things when i was working on my rear view mirror back up camera screen and their price was astronomical.
Tony (FL)
May 10, 2020 08:28 AM
Bruce
Feb 4, 2010 08:37 AM
trovan
Merchandise For Sale / Wanted
Mar 28, 2006 02:06 PM
Bruce
Feb 3, 2005 10:57 AM
firewired
Feb 20, 2004 11:38 AM
