Trunk open warning
Old Oct 26, 2018 | 12:32 PM
hkg1997's Avatar
hkg1997 is infamous around these parts
Trunk open warning
I was adjusting the trunk latch on my Vantage and after its done, when I start the car, a warning message came up about trunk open. I double checked everything and all are secured. What could have happened?
Old Oct 27, 2018 | 07:58 PM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
The sensor is really sensitive, mine keeps going off after I did not put put my golf bag in all the way and the strap got caught up in the the latch.
Old Oct 29, 2018 | 06:50 PM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
Mine lights up every now and then. I'll fix it one of these days, but for now it's just one of the quirks of the car.
Old Feb 3, 2024 | 11:00 PM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
Sorry for reviving this old thread, but I just got the "trunk open" warning on my car today, after installing the backup camera.
I had to remove the scuff plate and the trunk stayed open for 7 hours...
I tried removing the hatchback poppers and "slamming" the trunk , same result...
The problem is all lights inside the car stay on even when I am driving, and they turn off only when I lock the car.
Where can I find the "trunk open/closed" sensor?
Is there a module I need to reset?
Thanks!
Old Feb 4, 2024 | 12:18 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
I had that intermittently on my DB9. There's a microswitch that detects the trunk open condition, and mine was flaky.
I don't know much about microswitches so I replaced the whole latch unit. It's a Volvo part, less than $100. Never had the problem again.
Old Feb 4, 2024 | 08:03 PM
mbrandt1402's Avatar
mbrandt1402 is infamous around these partsmbrandt1402 is infamous around these parts
I removed the hatch striker plate for something un-related. It took several tries to get it positioned "just right" to make the trunk open warning go away. Perhaps you can find the sweet spot with some tinkering.
Old Feb 8, 2024 | 03:51 PM
DonBond's Avatar
DonBond is just really niceDonBond is just really niceDonBond is just really niceDonBond is just really nice
If you lean on the trunk sill you can very easily bend the latch mechanism. Mine wouldn't latch after having some stereo work done. I just grabbed the latch with my hands and gently pulled it up just a fuzz and bingo.....problem solved. They're kind of flimsy.
Old Feb 8, 2024 | 10:10 PM
EJ_Rapide's Avatar
That is the latch unit we're talking about, correct?
#1 in the diagram?
Old Feb 8, 2024 | 10:25 PM
yvr's Avatar
yvr
Yes, that's the part I replaced to solve my problem.
Old Feb 8, 2024 | 10:31 PM
EJ_Rapide's Avatar
Thank you!
I am looking into replacing the trunk poppers as well, I wonder if they just didn't give up after being released for so long...
DesotoJohn
Bentley
14
Oct 25, 2024 04:02 AM
Dgeedhar
Bentley
Dec 14, 2023 03:02 PM
Zaos
Bentley
Nov 14, 2021 11:04 AM
iambon
Sep 14, 2012 12:37 PM
