Squeaky belt?
Old Feb 24, 2019 | 10:26 AM
Xler8nAMV's Avatar
Xler8nAMV is just really niceXler8nAMV is just really niceXler8nAMV is just really niceXler8nAMV is just really nice
Squeaky belt?
Hi all,
So I noticed at the weather got cold here I have a very squeaky belt noise going on. It’s very loud on startup but after a bit of driving and warmup it seems to go away. Any idea with what I’m dealing with here? Fan belt? Average cost? Possibly just tighten? Your wealth of knowledge is welcomed! TIA....
Old Feb 24, 2019 | 10:30 AM
Xler8nAMV's Avatar
Driving an 07 Vantage V8 btw...
Old Feb 24, 2019 | 10:45 AM
Hedged's Avatar
Hedged is a jewel in the roughHedged is a jewel in the roughHedged is a jewel in the rough
Search forum under FEAD belt....known design issue with earlier Vantage. Rich at Redpants has a nice video regarding this.
Old Feb 24, 2019 | 01:15 PM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
New serpentine belt and upgraded pully will sort it out, many of us had this thorn.
Old Feb 25, 2019 | 01:13 AM
V8Vantage007's Avatar
V8Vantage007 is infamous around these parts
Wondering if this is a necessary upgrade or it can wait, despite it being annoying. I had this infamous squeal shortly after I purchased the car at 21k miles, then drove the car hard and the sound went away. It doesn't look like the pulley does any damage to the belt, just causes it to squeal from time to time.
That being said, I'll probably replace it down the road but will hold off if it's not necessary or going to cause the belt to snap.
Old Feb 25, 2019 | 05:53 AM
GDay2's Avatar
GDay2 is a jewel in the roughGDay2 is a jewel in the roughGDay2 is a jewel in the rough
I had the squeaky belt issue 2 years ago and found a simple remedy, see at the bottom of my page here: v8v.info
Cheers
Christian
Old Feb 25, 2019 | 03:24 PM
Xler8nAMV's Avatar
Thanks so much. Def going to try this first. Can’t hurt! Appreciate the resistance all. Always so helpful in here!
Cheers
Christian
Old Feb 27, 2019 | 04:03 PM
Xler8nAMV's Avatar
So did you just spray this directly on the belt? Top and bottom? While running or shut off? Got the 303 in and wanted to hit it soon. Fingers crossed it will work!
Cheers
Christian
Old Feb 28, 2019 | 02:36 AM
GDay2's Avatar
I sprayed it on with the engine running both sides of the belt, a bit hard to to get the bottle in and you got to be careful not to touch moving parts but it was worth the effort.
Cheers
Christian
Old Feb 28, 2019 | 07:05 AM
yankee04's Avatar
yankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond repute
I previously owned the Vantage in Rich's video. As we came to find out, the terrible mechanics at AM of Washington DC replaced the pulley under warranty but reinstalled the original belt! The pulley guide rails chewed up the sides because it didn't fit correctly. Belt squeak was coming from the belt not the pulley. So glad I didn't end up on the side of the road. Inspect your setup to be sure previous mechanics didn't make the same mistake.
Old Mar 2, 2019 | 10:11 AM
Xler8nAMV's Avatar
Cheers
Christian
Thank you, thank you! This should become a sticky. I had no belt wear and after only one spray and then starting the engine, the problem was gone. Then a few more sprays for good measure. $13 over a few hundred was a big time and effort saver! Had my doubts but the 303 did the trick. Thanks again. Amazing how this forum is simply a wealth of knowledge!!! Appreciate all of your responses...
Old Mar 19, 2020 | 06:03 PM
DVLINSID's Avatar
DVLINSID is infamous around these parts
Dumb Question from a non-Mechanical person
I own a 2009 AM Vantage Roadster, and I am now also getting that "squeak" from my belt.... I saw the replies here regarding "303" and it seems promising.
So here goes the "dumb question"... how do I access the belt? Do I need to be under the car, or can I access it from under the hood?
I dont want to damage anything with the 303 accidentally but DO want to get rid of this annoying Squeak that seems to be getting worse.
Thank you for the help!!
Old Mar 20, 2020 | 05:24 AM
GDay2's Avatar
Just open the bonnet and look for the belt in the front of the engine, you cannot miss it it is quite visible. I sprayed mine with the engine idling to get at full length - just be careful wit the moving parts!
Cheers
Christian
Old Mar 20, 2020 | 09:37 AM
DVLINSID's Avatar
Thanks Christian, Ill try that!
Old Mar 24, 2020 | 12:30 PM
DVLINSID's Avatar
Christian... Just an update, the 303 arrived from Amazon, and as you said, I did a few sprays on to the belt and miraculously the squeak and squeal is GONE!! Best $21USD spent EVER.
Thanks my friend!
