Cheapest places to buy oil and brake fluid
Old Sep 10, 2019 | 11:17 PM
lovingit's Avatar
lovingit is infamous around these parts
Hi everyone,
I want to source my own oil for my AM V8V 4.7. People recommend the Castrol 10W60. I found it on Amazon for $120 for 12 liters. I believe my 4.7L takes 10 liters......not sure?
Is Amazon the cheapest?
https://www.amazon.com/Castrol-SUPERCAR-10W-60-Advanced-Synthetic/dp/B0161A4CIS/ref=sr_1_2?keywords=castrol+10w60&qid=1568178977&s =gateway&smid=ATVPDKIKX0DER&sr=8-2
Is brake fluid Castrol SRF? Any others suitable brands? This is done once every 2 years right?
Amazon is kind of expensive. If it is this bottle, it is $95 each.
https://www.amazon.com/Castrol-SRF-Racing-Brake-Fluid/dp/B000JL760C/ref=sr_1_2?keywords=Castrol+SRF+brake&qid=15681787 50&s=gateway&sr=8-2
Old Sep 11, 2019 | 09:38 AM
Mathman85's Avatar
Mathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to all
You can get two 5L jugs of Motul 8100 X-Power 10W60 for $84 on Amazon.
And Castrol SRF is great, but ultra expensive, and you have to take into account volume... your car needs 1.5L, and those come in 1L bottles, so you'd need two and you'd be wasting a half liter (once you open it, you can't let it sit for too long, so it'd be a waste). I run Motul RBF 600 on my car (and I track it), and you can get that in 0.5L bottles, so you'd need three and it'll work just as well. If you track your car A LOT, go with the SRF... but the RBF 600 is fantastic for street cars that get tracked occasionally. (And it has a higher wet boiling point than the RBF 660, which is why I run 600.)
Old Sep 11, 2019 | 11:57 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
I have good luck at Autozone.
Old Sep 11, 2019 | 08:02 PM
cuddapah's Avatar
cuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond repute
I would suggest to stick with Castrol React SRF or whatever the manual says. For my DB9, I noticed a lot of difference with Castrol React SRF and others.
Old Sep 11, 2019 | 09:22 PM
007JB's Avatar
007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light
IMO: I would use Castrol brand for engine oil, as far as for brake fluid, get German brand DOT4 ( Ate or something similar) fluid, unless you're planning to track it..2 liter should do it. should not be more than $25 each. don't waste your $$$ on brake fluid..
Old Sep 16, 2019 | 06:14 PM
Gene G's Avatar
Gene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond repute
Try eBay. I bought the oil to do all if my cars there this year. It is nice having it shipped to your home. Just search for the oil you need then sort it by price lowest.
Old Sep 17, 2019 | 01:35 PM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
The manual says any Fully Synthetic 5W-50 or 10W-60 oil to specification ACEA A3/B3 is acceptable. There's nothing magic about Castrol.
Old Sep 17, 2019 | 01:38 PM
blue2000s's Avatar
Why would oil sitting in a jug go bad over the course of a year? It's not hygroscopic and it's not unstable. As long as you're not contaminating it in some way, it's perfectly fine to use on the next oil change.
Old Sep 17, 2019 | 02:42 PM
cuddapah's Avatar
I was referring to brake fluid. My DB9 manual says "React Performance DOT 4". Here is link to an excellent article from Rich's site.
https://www.redpants.lol/brake-fluid-comparison/
Old Sep 18, 2019 | 09:21 AM
Mathman85's Avatar
Just as with the other comment, you're confusing brake fluid and motor oil. Brake fluid IS hygroscopic, and that's what my entire second paragraph is referring to.
Sobrut911
Feb 17, 2013 07:58 PM
monojohn
Nov 29, 2012 02:44 PM
pumalex
Jun 9, 2010 09:43 PM
02_996TT
Jun 12, 2008 01:11 PM
rkg
Nov 19, 2007 01:49 PM
