2012 Aston Martin V8 Vantage brakes!
Old Nov 12, 2019 | 07:29 AM
teddy_lee2000's Avatar
teddy_lee2000 is infamous around these parts
Hey Guys,
Just purchased my 2012 Aston Martin V8 Vantage and I got the "rear brake pads low" sign today.
1. Anyone know where I can get aftermarket pads that wont give me a sensor issue that is not terribly costly?
2. Approximate install time?
3. I believe maintenance on these are annual but it doesn't have a date or mileage countdown, so do I just wait until the car tells me its time for service?
Sorry for the basic questions, I am new and learning!
Thanks!
Old Nov 12, 2019 | 10:22 AM
NotanM's Avatar
NotanM is infamous around these parts
Originally Posted by teddy_lee2000
Hey Guys,
1. Anyone know where I can get aftermarket pads that wont give me a sensor issue that is not terribly costly? - Try some porterfiled pads & sensors.
2. Approximate install time? 1-2hrs
3. I believe maintenance on these are annual but it doesn't have a date or mileage countdown, so do I just wait until the car tells me its time for service? Car will tell you 12 months after the SRL was reset. Its either 12m or 10k miles...most its 12m. Might be a good idea to check the oil, refer to your owner's manual for the proper way to check the oil on your V8V
Thanks!
Hope this helps
Old Nov 12, 2019 | 10:47 AM
JPS-ATL's Avatar
JPS-ATL is infamous around these parts
One more vote for Porterfield R4-S. Lot's of information and DIY at redpants.lol where you can also buy pads. I got mine earlier this year from Topbrakes for $153.
Job is pretty simple as Brembo setup doesn't require removal of caliper. I'm in ATL if you need help.
Old Nov 12, 2019 | 11:08 AM
Thanks for that guys!
Old Nov 12, 2019 | 12:02 PM
NotanM's Avatar
Just make sure you install the pads in the correct direction.
Old Nov 12, 2019 | 12:06 PM
Good tip!
Old Nov 12, 2019 | 12:11 PM
JPS-ATL's Avatar
I'm embarrassed to say that I made that mistake once last year on my E30 track car :-(
Was at the track rushing to change pads in between sessions.
Old Nov 12, 2019 | 12:54 PM
I found the Porterfield R4-S pads but I cannot find the sensors or rotors!
Old Nov 12, 2019 | 01:03 PM
JPS-ATL's Avatar
Try Scuderia Parts, but measure existing rotor thickness first to see whether they need replacing. Replacing the rotors is a more time consuming job as you have to remove both the main calipers and the handbrake calipers.
https://www.scuderiacarparts.com/par...isc-1-oes.html
Old Nov 12, 2019 | 02:02 PM
Thats perfect! I think I might have to change out the rotors regardless of thickness. There are some small grooves on my current rotor which would overtime destroy my new pads.
got one
Sep 11, 2019 05:55 PM
tko211
Feb 21, 2019 06:01 PM
timwhayden
Sep 14, 2013 05:52 PM
007 Vantage
Nov 9, 2012 02:32 PM
007 Vantage
Oct 25, 2012 02:56 PM
