2007 V8V - I'm making a list...
FYI, if you haven't accessed that fuse box yet, you'll need a T27 (I believe) Torx bit to remove the seven bolts.
Yes, T30. I took the panel off earlier today, and it was a bit of a pain to locate the fuses in question. One of them is behind a wiring loom, but hopefully won't be too tough to remove/replace when I find an appropriate set of pliers.
in fact, i would probably take the trouble to stuff a towel in there somehow to prevent that from happening to me.
i use a pair of needle nosed pliers. and am careful to NOT DROP THE FUSE INTO THE BOTTOM OF THE FUSE ENCLOSURE. this is possible and not a pleasant experience.
Some good news. The car came through its 40k service without a hitch - the only thing reported was the need for new front brake pads. I may just go for the Hawk HPS 5.0 from Redpants, as I've had a good experience with those from back in my Porsche days.
Bad news - the fuse pull only seemed to work for the passenger door - I'll try the relearn procedure again. AND, now I get a new error message about the passenger side airbag needing service😣 I think I could do with a new battery.
Aside from that, a question for my fellow owners. I want to invest in a good set of ratcheting wrenches. Would this set cover most or all of what I'd need to do with the Vantage -
Thanks!
Thanks!
IDK about those Hawks. I have them on a 335i, and while I love the strong initial bite, they are very dusty and squeal a lot. On my V8V, I just replaced the stock pads with Carbotech 1521 compound for the sole purpose of reducing dust. I haven’t pushed them hard yet, but my initial impressions are favorable. Quiet and pretty much identical feel to stock. Dust is 85% better, and since it’s more grey than black, it’s much less apparent.
BTW - why does it have to be so difficult to find a set of front and rear pads at most online sellers?🙄 Do they just sell significantly more front pads?
I have had older HPS pads on an Rx-7 with black wheels for a very long time, they stay pretty darn clean.
*usually* you will replace fronts at least 2x more often than rear. Unless these cars have more of a rear bias, for some reason. Also, depending on how much your traction control kicks in, I could see the rear pads wearing a bit faster than "normal".. but probably not enough to make a huge difference.
The passenger airbag warning is now gone
The fix - push the seat forward. I'd put it back to make more room for access to the fuse box, and a process of elimination confirmed that this was indeed the reason for the error.
often, when working on the car (or occasionally napping in the passenger's seat on a long days' drive) and moving the passenger seat forward and backward and/or moving the seatback forward or backward, or setting anything in the seat some error message or another shows up referencing the air bag. i've learned to ignore it. sometimes it goes away on its own sometimes not. if not, moving the seat forward or backward to the max usually sets things straight (on occasion i've prayed). there are a lot of bugs in the software on cars these days such that even the dealerships are sometimes mystified.
