Lowering springs/wheel spacers for DB9?
Old Jun 2, 2020 | 03:34 PM
GrantRR's Avatar
GrantRR is infamous around these parts
Anyone have pictures of a DB9 lowered on springs and or with wheel spacers? Anyone have a set for sale?
Old Jun 2, 2020 | 06:59 PM
J doubleU's Avatar
Velocity AP for the springs. ?
Old Jun 3, 2020 | 01:37 PM
8Tech's Avatar
5 Year Member
8Tech is infamous around these parts
2005 DB9 on Eibach springs with Bilstein coil-over adjustable shocks. 6mm spacers front and rear wih 305/30 x 20 on rear and 255/35 x 20 front.
Old Jun 3, 2020 | 04:09 PM
Theotherjames's Avatar
Theotherjames is infamous around these parts
If you're running stock 19's W/O a drop, 11mm spacers on the rear give it a much better OEM look. It's not all the way flush, but it brings it to typical "OEM flush" if that makes any sense, whereas the before was under and just way too noticeably sunken in.
These are not the best pictures to show off the flushness, but it gives you a general idea of how they'd look from typical viewing distances.
Old Jun 4, 2020 | 11:47 AM
TiAg's Avatar
TiAg is infamous around these parts
I have a brand new set of H&R spacers for sale. See link below.
I got them for my Vantage but these should fit a DB9 as well. Willing to make a deal if you are interested.
https://www.6speedonline.com/forums/...cers-23mm.html
Old Jun 4, 2020 | 01:53 PM
sdekoning's Avatar
sdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to behold
2004 (production no. 311) DB9 on H&R springs and with 13mm front and 18mm rear spacers with longer studs and zero wheel well rub. I initially used adapters at the rear but the flex on them scared me, thus I went with longer threaded studs.
It's been properly polished since
Old Jun 4, 2020 | 10:53 PM
zzzamdb9's Avatar
5 Year Member
zzzamdb9 is infamous around these parts
Do you have the part numbers for the Bilsteins? When I go on the Bilstein website they don’t list any options for the DB9.
Old Jun 5, 2020 | 05:20 PM
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
Just get the VelocityAP springs OR get a set of coilover adjustables. IMHO the other companies springs lower them too much.
ALSO-----get a set of BC Forged wheels and have them set to the correct offset. SPecers are ok if new studs are installed, but why not do it right and get wheels to correct the offset and get the 20" wheels which look a ton better on the car. Pics below, same wheels and springs, but different looks.
SheriffDep
Sep 7, 2016 10:46 AM
sdekoning
Mar 28, 2015 07:35 PM
911ist
Sep 5, 2012 09:30 AM
