Tail Light Repair?
Old Sep 4, 2020 | 05:17 PM
XJRS Owner's Avatar
Tail Light Repair?
Anyone have a source for repair of a non functioning brake light in the sealed tail light unit? Don’t feel like shelling out for a new cluster if I can avoid it.
Old Sep 4, 2020 | 05:33 PM
I_gotta_Vantage's Avatar
5 Year Member
I_gotta_Vantage is infamous around these parts
I had to get a used one off ebay... you cant really fix those LED’s. And replacing them with aftermarket is even more...
one of the worst replacement parts on the AM...
Old Sep 5, 2020 | 12:12 AM
PFTF's Avatar
PFTF is infamous around these parts
I have condensation in mine, and though they're still functional at the moment I'm prepared for them to fail. I looked around for repair services and found these guys (Divinatech).
Having said all that, the dealer told me that despite my car having the CPO timeless warranty, the headlights and taillights were not covered for condensation damage. Is this true, or is the dealer full of it?
Note: I have not used that vendor, and as I have no idea if they're either competent or legitimate I'm not endorsing them.
Old Sep 5, 2020 | 05:00 AM
5 Year Member
Yes, the condensation in the rear tail lights is common... not good at all but it happens to these lights... these lights fixings have no rubber seal for moisture. Have you seen one open? I can share a pic of the inside.... they are very easy to remove...
AM dealerships do stay away from the moisture issue...
Old Sep 5, 2020 | 09:10 AM
XJRS Owner's Avatar
I’ve heard of Divinatech, thanks for the reminder. I bought from them some time ago when they had just started as a hobby-based business. I’ll check it out.
Old Sep 5, 2020 | 01:10 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Pretty sure Divinatech is member "divetheworld" on PH
Old Sep 5, 2020 | 05:34 PM
61mga's Avatar
61mga is infamous around these parts
unless and until i found a DIY article or video describing a better method and before spending a dime on an expensive replacement, i would drill a small hole somewhere inconspicuous and put it in a warm place for a few days. if that didn't work, i would drill another hole and place a hair dryer over one hole and run it for a day or two. if it drys things out i'd put a drop of super glue over each hole and see how things go. if it didn't work? well, i've sacrificed a week or two's time and next to nothing money-wise. and i still have a worthless taillight.
...now that i think about it, i recall a DIY project (youtube?) where the lens was removed using a micro-wave oven or something...looked awfully complicated.
Old Sep 5, 2020 | 05:52 PM
ROBERTSCOTTNEILLY's Avatar
ROBERTSCOTTNEILLY is infamous around these parts
Sorry, XJRS Owner; what year/model are we talking about?
Old Sep 6, 2020 | 06:47 AM
Bones 53's Avatar
5 Year Member
Bones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud of
I believe if your lights fail they would be covered under the warranty.
Dealers have a lot of leeway on this issue. My dealer has replaced mine three times for condensation...no charge.
Thanks,
JH
Old Sep 6, 2020 | 09:45 AM
XJRS Owner's Avatar
Gen 2 Vanquish
Old Sep 7, 2020 | 08:18 AM
I have a complete functioning left light, and a disassembled right one; the problem with it is the control 'module' which has an internal fault. The LED array is fully functional. Fits '06 to '09 Vantages; not sure what else?
Old Sep 11, 2020 | 05:49 PM
JPS-ATL's Avatar
JPS-ATL is infamous around these parts
I'm interested. Sent you a PM.
Old Sep 11, 2020 | 06:22 PM
spinecho's Avatar
spinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to behold
Thanks,
JH
I, too have had a supportive dealership. Old V8V unit replaced under warranty. Also had a V!2V unit resealed and repositioned / remounted out of warranty, no charge, with no recurrence of condensation. As you say I think they have a lot of wiggle room on issues like this.
thisistcab7
Jan 7, 2026 11:18 AM
Ametcalf
Aug 10, 2020 08:55 PM
mrsiyufy
Aug 20, 2019 06:39 PM
Squat
Jul 30, 2012 06:36 AM
