lug nuts
Old Dec 27, 2020 | 07:46 PM
branjk's Avatar
branjk is infamous around these parts
lug nuts
I am looking at getting custom wheels, black in color and need black lug nuts. I have looked around and struggled to find black lug nuts for a Vantage 2015. i have seen the ones on ebay and not to excited by them. Plus the ones i saw said torque down to 100 lb/ft, but they need to be 123 lb/ft. Also looked at astonmartinbits.com and saw only individual ones, non black. RedPants i thought sold them but i cant find them on his website now. I could take my existing one and plasti-dip them but i have no experience with that option. So I am wondering if any one knows a reliable place to get them? Also is it critical to have the 2 piece design? My understanding is that protects the wheel while tightening them down.
Old Dec 27, 2020 | 08:10 PM
dz22's Avatar
dz22 is infamous around these parts
I believe the thread pitch is M14x2. Google that and you should be able to find a black lug nut. I believe Gorilla makes some.
Also, a two piece design is not needed, but ensure the lug nuts are a conical seat assuming that's what your new wheels require.
Old Dec 27, 2020 | 08:29 PM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
Make sure you are buying lug nuts that match the wheels. The cone angle, flat or rounded, integrated or separate all should match the wheel requirements. Does the manufacturer have a recommendation?
Old Dec 27, 2020 | 08:45 PM
branjk's Avatar
all good points. i will ask. its BC Forge, so they should have knowledge about the fit
Old Dec 27, 2020 | 09:22 PM
dz22's Avatar
I've had two sets of BC Forged wheels. You'll want 60 degree taper conical lug nuts.
A few options:
https://www.systemmotorsports.com/co...lock-set-black
https://www.systemmotorsports.com/co...ugnuts-m14x1-5
https://www.systemmotorsports.com/co...12462060372069
Edit: Made a mistake, V8 Vantage uses M14x2.0
Old Dec 28, 2020 | 06:17 AM
branjk's Avatar
great thanks
Old Dec 28, 2020 | 11:00 AM
Deplorable1's Avatar
5 Year Member
Deplorable1 is infamous around these parts
My 06 V8 calls for 14x2.0, Hard to find nice Brushed or Lightweight......
Old Dec 28, 2020 | 02:03 PM
dz22's Avatar
Originally Posted by hsm precision
Interesting that these are aluminum wheel nuts? I've not seen this before. Any concerns using aluminum vs steel or titanium. (the ones in the link are 7075, so stronger than regular 6160, but still, not as strong.)
Matt
Are you alluding to an alternative? Feel free to share if so. I've been looking for some lug nuts myself and have not found exactly what I'm looking for.
Old Dec 28, 2020 | 03:50 PM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Are these the ones you looked at on ebay?
US made of cold forged steel...they are not the two piece design, but might be suitable depending on the aftermarket wheels you select. Price is right at $19 plus shipping for 20.
https://www.ebay.com/itm/20-Bulge-Ac...75.c100623.m-1
Old Dec 28, 2020 | 05:15 PM
dz22's Avatar
Yes, you're completely right. I misspoke with 14x1.5.
I don't have any good suggestions unfortunately. Titanium is $$, and steel is more or less the standard. The fact that 7075 nuts are being sold indicated that it's strong enough, and opens up the possibilities of making them (I can make 7075 parts cost effectively - titanium is much harder).
I'll need to see if I can come up with a decent prototype. I have some 6061 on hand, and maybe some 7075 that is wide enough
If you have some specific ideas needs, I'd like to hear the details - maybe I can make something that'll work.
Matt
Something like this would be great in m14x2.00 with an open ended design and perhaps closer to 40mm long. Do you do custom work like this? If so, feel free to PM me. Thanks!
https://ozmoengineering.com/shop/m14...nical-lugnuts/
Old Dec 28, 2020 | 05:49 PM
5 Year Member
Found these after E mailing Them, Didn't Notice the Nuts in the Right corner, Shows To Fit up to 17.
Just Purchased Paypal will give Review when Recieded, I've Bought Many Ti Bolts/ Nuts & Other Bearings From This CO, Top Notch Stuff.
I Have these factory Black/Brushed Wheels From a 15 GT, Should Look Good.
https://www.acerracing.com/products/...14347950391331
Please choose your version. The Vantage for years up to and including 2017 (before the redesign) used a 2.0 thread pitch nut.
Old Dec 29, 2020 | 10:15 AM
Kalepsis's Avatar
5 Year Member
Kalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to all
My opinion is to stick with the stock 2-piece lug nuts. They're very good, and I think they look great on those GT wheels (I bought a set of the same ones myself; just waiting on tires). I would, however, recommend black Aston center caps... but they're also stupidly expensive.
FYI, if your lug nuts are 21mm, the torque is 133 ft.lbs., after a run-in torque of 60. 123 ft.lbs. is for the 22mm nuts on the 06-08 models.
Old Dec 29, 2020 | 02:32 PM
MichaelD's Avatar
MichaelD is infamous around these parts
The black Aston centre caps are surprisingly cheap in the UK, around £17 each, even from a main dealer, so they shouldn't be expensive over there
Old Dec 30, 2020 | 09:13 PM
GWP's Avatar
GWP
5 Year Member
GWP is infamous around these parts
wheelspacers.uk.com
Saw some black ones on their site the other day.
Old Jan 1, 2021 | 10:08 AM
5 Year Member
They showed up rather Quick for the pretty lame USPS these days, and once again this company Nailed it !
These are fantastic and look great, The brushed look is perfect & half the weight was a Plus.
I’ve been doing Porsche's for 20 years now and always had a few people neg on the titanium, but it is absolutely never had an issue on my cars, including my daily driver that has bolts that have been on and off the car through at least four sets of tires, and they still look new.
I was surprised that stock only takes about six turns, I will double check and make sure I get Depth before I put them on without the wheel,
I have bought titanium lugs from another company, and they do black maybe there’s a way somebody can anodize these black for them if they need it.
MothXz
Jul 20, 2012 03:36 PM
raclaims
Feb 23, 2010 05:05 PM
996garage
Feb 4, 2008 06:45 PM
cayenne-tt
Dec 29, 2007 10:01 AM
