Rapide: Alternative Brembo Pads
Only been an Aston owner since the start of the year but wanted to share with you alternative Brembo pads for the Rapide as I couldn't find this information.
The only caveat with the pads I have found is they have slightly different brake sensor locations for 3 wheels. I can confirm they fit, as I have personally fitted the parts to my car however the usual disclaimer of use at your own risk applies.
I've also listed the cars they fit, which opens up a whole host of pad options should you want to venture away from OEM.
Also listed the price I paid as a guide (I needed vendors with good rates for international postage so you may well find better deals)
Front Pads
Car: 2017 Maserati Levante S
Set, including spring, shims & pins Brembo Spare Part Code: 107.7783.73
Pad Code: 07.7783.73, 07.7783.74
Springs, pins and shims also fit the Rapide
I paid US$230 inc spring pins and shims
Front Pad Label
Front spring and Pins
Aston vs Maserati Fronts
Same Jurid plate number
Only difference is the wear sensor is a different location, so will have to remove the slack for the brake sensor wire
Rear Pads
Brembo P85 116
Cars: Ferrari 612 Scaglietti 04-11 (Front) , Audi TT 2.5 RS Quattro (8J9) (Front)
Wear sensor will be in a different position for the rear left caliper (see photo)
Pads come with sticky adhesive backing for shims, this is easily removed.
US$85
Rear brake, different sensor location (One side only)
Parking Brake (for completeness)
Brembo P02 001
These are the only pad listed in the Brembo catalogue for the Rapide.
Front Pads
Front Pad Label
Rear Pads
Brembo P85 116
US$85
Brembo P02 001
Alternative pads for Vantage V8S and Rapide/S
AP1990 front
AP1165 rear
https://www.porterfieldbrakes.co.uk/...html?cars=1516
https://shop.redpants.lol/product/po...ake-pads-1990/
AP1990 front
AP1165 rear
