V8V AC Compressor replacement options
Old Jun 1, 2024 | 09:46 AM
spawnywhippet's Avatar
spawnywhippet has a spectacular aura aboutspawnywhippet has a spectacular aura aboutspawnywhippet has a spectacular aura about
Originally Posted by AM4884
Good luck. the other "option" is that it has slow leaked down and you've lost oil as well. Should you replace the compressor with the old one, be sure to add oil. I had this issue recently with another vehicle - it was making grumbling noises. I added 4 ounces of oil and it quieted up. (4 which is about 1/2 of the total fill for that installation).
Thanks for that info. is the oil added through the regassing valves?
Old Jun 1, 2024 | 04:08 PM
Well that didn't go as planned. While removing the old AC clutch, the bolt head broke off leaving the clutch in place and not removable. I guess I will need to replace the entire unit now.
mike_787
Jun 21, 2017 08:21 PM
born2boost
Aug 28, 2013 12:36 AM
SeattleBum
Sep 2, 2010 03:53 PM
JSmith5690
Aug 4, 2008 05:24 PM
