V8 Vantage CV Joint Axle/Halfshaft boot repair DIY
Old Jun 7, 2021 | 06:28 PM
Tremelune's Avatar
Tremelune is infamous around these parts
Talking V8 Vantage CV Joint Axle/Halfshaft boot repair DIY
One day I noticed my right halfshaft boot had been torn. A new one was $800 from Scuderia, and mine wasn't making any noises (it had only been torn for a week or so before I noticed), so decided to fix it with a Flexx Boot that didn't require taking apart the CV joint.
It's fairly straightforward, but worthy of noting:
1) The new bolts I got from Scuderia were maybe 5mm longer than what was there. No issue, though.
2) The left side of the car has the ride height sensor that informs the headlight levelers...There isn't much space to get the axle out, and I wound up snapping the arm on mine. It's like one bolt to remove, so...whoops.
3) Keep the axle nut tight until you remove the halfshaft from the gearbox...It's a tight fit.
4) A powered ratchet will be your best friend, and you'll need a torque wrench capable of 300Nm/222ft-lb.
I couldn't find a video on it, so I made my own. Hopefully it'll be helpful to someone in the future:
Old Jun 8, 2021 | 10:03 AM
PJK's Avatar
PJK
PJK is infamous around these parts
Loved the video... You sound just like me on every project I've done!
ralph s3
Jul 20, 2022 11:42 AM
SpeedAddict
Nov 15, 2021 05:19 PM
terminal_ac
May 8, 2015 01:26 PM
Pierre996TT
Cayenne 955/957
14
Jan 26, 2013 07:46 PM
zambono
Sep 2, 2009 11:11 PM
