Spacers
Old Feb 7, 2025 | 06:10 AM
Matt(inMA)'s Avatar
Matt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud ofMatt(inMA) has much to be proud of
Speaking of spacers - I bought a set of four 20mm for my '23 Vantage. They fit wonderfully on the rear but are too wide for the front. Looking for a pair of 10MM(ish) spacers and have a pair of 20mm if anyone is interested.
Old Feb 7, 2025 | 06:26 AM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
I've always had spacers on my Vantages (or larger wheels with offsets) - makes a huge difference in the looks, zero issues. I've also had spacers on my AMG SLK's - again no issues. I'm close to ordering a M2 BMW - first thing will be those spacers.
Old Mar 19, 2025 | 12:16 PM
downeaster1's Avatar
downeaster1 is infamous around these parts
I had a set of macht schnell for my old F80, and it was perfect.
Old Mar 24, 2025 | 09:17 AM
Ray F's Avatar
5 Year Member
Ray F is infamous around these parts
So do you have 11mm on both front and rear?
I’m thinking of adding spacers to my ‘08 DBS.
Thanks, Ray.
QUOTE=Gene G;4880160]I know there have been several treads on spacers. I just put 11mm H&R spacers with the extended thread lug nuts on both the front and rear. I think that the wheels on my car must be wider than some others because I’m sure that 23mm spacers
on the rear would be too much. The tires on my Vantage are 285x35x19 on the rear and 245x40x19 on the front. Anyway I’m very happy with the way it looks now.
[/QUOTE]
Old Mar 27, 2025 | 04:53 PM
Gene G's Avatar
Gene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond repute
Yes I did, but I no longer have the Vantage. I now have a 2016 Vanquish.
Old Mar 27, 2025 | 06:28 PM
OjaiM5's Avatar
5 Year Member
OjaiM5 has a spectacular aura aboutOjaiM5 has a spectacular aura aboutOjaiM5 has a spectacular aura about
Where did you guys get the extended studs? I pulled my 11mm spacers off my front because I was not comfortable with not getting enough treads on the lugs.
I really don't like the look of the wheels being sucked in the wheelwell.
Old Mar 28, 2025 | 07:11 AM
Gene G's Avatar
I bought mine on eBay they are made by H&R.
Old Mar 28, 2025 | 01:43 PM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
Like Gene, I've purchased longer lug bolts on Ebay.
As a "general" engineering rule, (specific applications can vary), the retaining bolt (lug bolt in this case) should thread in, at a minimum, the diameter of the thread. So, a 14mm lug should thread in at least 14mm.
philjes
Nov 24, 2018 01:35 PM
scatkins
Jun 8, 2014 10:56 PM
quick
Jul 16, 2012 04:57 PM
euroaaron12
BMW //M
Dec 27, 2007 08:17 PM
