How do I add an Aux input or bluetooth to the 07 V8V?
Old Aug 5, 2021 | 11:27 PM
str8csh's Avatar
str8csh is infamous around these parts
I went with GROM audio to add bluetooth / aux in to my 2007 V8V with premium audio. It sounds very similar to the description of Mr12Volt in that it takes the place of the CD player in the system. It's been a few years now and I've had no issues with connection or quality. Almost positive I found a write-up in the forums for the install. I believe you'll want the Volvo XC90 Single CD 2007-2013 model if you are so inclined.
Old Dec 24, 2021 | 11:11 PM
pld118's Avatar
pld118 is infamous around these parts
Read this thread with interest:
For a 2002 DB7 Vantage is the Sony DSX about as good as you need?
Car isn't a daily driver/ used on days off work occasional use. Was thinking about a BT module to connect to the existing Becker CD changer in the boot but some posts suggest the consistency isn't that good?
Required use would be iPhone integration to play music through the phone, maybe use the phone's sat nav, use the phone hands free without having to wire in additional speakers around the A-pillar; and listen to the radio.
I don't think the OP's Sony DSX unit has DAB and have found this one which does:
Sony DAB radio Bluetooth media receiver DSX-A510D £129 GBP
https://www.sony.co.uk/electronics/i...ers/dsx-a510bd
Any thoughts on the quality of these units and if they're a straight swap by removing the Becker head unit, then plug and play the new unit (I would preserve the Becker unit for future originality purposes and wouldn't have the CD changer connected, unless it's easily done - because I would probably not use CDs if having access to smartphone music)?
Thanks.
Old Dec 25, 2021 | 01:17 PM
61mga's Avatar
61mga is infamous around these parts
Originally Posted by dyc1077
how is the sound quality of the phone call through mr12volt?
the sound is played on your car stereo speakers, so it will sound as good as your speakers. my car has the Premium sound system option.
Old Dec 25, 2021 | 01:29 PM
J doubleU's Avatar
My pickup had that until I upgraded to Alpine.
Old Dec 25, 2021 | 01:32 PM
61mga's Avatar
Originally Posted by blue2000s
That's a good one! Is there a switch to go between the CD changer and Mr12V? Does the screen just display as it's playing a CD?
If you don't care to control an iPod and would rather use bluetooth, this certainly looks like a less expensive but completely viable option. The Dension requires an additional iPod to bluetooth adapter to do the same and is much more expensive.
your head unit will need to be set in CD mode and to track 1 and then paired using your phone.
the screen on the head unit will scroll a bit of info about the track that's playing and something different when using your phone. can't say really, because i don't use my phone much while in the car. the power supply for mr12volt needs to be UNSWITCHED. meaning the that it will receive power even when the ignition's turned off. otherwise, you'll have to pair it with your phone on occasion.
the phone needs to have bluetooth turned and i set all the the bluetooth pairing toggles to the ON position.
Old Jan 2, 2022 | 10:12 AM
Newtonian's Avatar
Newtonian is infamous around these parts
The Mr12volt carplay version doesn't see to support Volvo/AM. Has anyone tried NAVtool? https://www.navtool.com/aston-martin...e-carplay.aspx
Old Jan 30, 2022 | 11:17 AM
Tremelune's Avatar
Tremelune is infamous around these parts
mr12volt is the best solution at the moment. Here are the details of my install:
https://www.6speedonline.com/forums/...-vantages.html
Old Jan 30, 2022 | 12:40 PM
Newtonian's Avatar
Thanks for posting!
AlecS
Jan 30, 2022 04:34 AM
dandelos
Cayenne 955/957
Jul 1, 2013 01:13 PM
FlyYellow
Cayenne 955/957
30
Nov 13, 2012 05:00 PM
MiniSuperDuke
Cayenne 955/957
May 17, 2012 10:06 AM
