Just how 'leaky' is your Aston Martin?
Old Aug 5, 2022 | 11:32 AM
SLVRon's Avatar
5 Year Member
SLVRon is infamous around these parts
Angry Just how 'leaky' is your Aston Martin?
When I bought my 2007 V8 Vantage a couple of years ago I was aware of the 'weeping' from the timing cover, which turned into a minor leak. I had a clean garage floor for a while after having that fixed, but after a recent drive I noticed a new leak from a different spot (closer to the driver's side). Naturally I'll monitor and get to the bottom of this one, but I'm wondering if this will be a constant chase? I know that cars driven less frequently are more prone to this, and not all leaks need 24 hours of labor to fix like the timing cover one, but what's everyone else's experience with this?
Old Aug 5, 2022 | 03:23 PM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
My (new) 2015 V8GT had a timing cover leak as well as a transaxle leak - not enough to drop oil on the floor - more of a weep. Both fixed under warranty. My current Vantage has a timing cover weep and one valve cover weep, again not enough to drop oil on the floor. My 2007 Vantage, a 2009 Vantage, two 2015 V12S and a 2017 V12S all remained bone dry. The GT had a pinch of the seal/gasket during assembly - so much for 'hand made'.
Old Aug 6, 2022 | 04:35 PM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
My V8V had a weep, borderline leak. One of the reasons among a few I traded it in for the Rapide.
Old Aug 6, 2022 | 08:11 PM
Mike Gray's Avatar
5 Year Member
Mike Gray is infamous around these parts
My 2013 V8V is dry as a bone at 20.5K. After I got the timing cover leak fixed a couple of years ago!
I just can't abide a car that leaks. With the exception of my 1989 Alfa Romeo Milano - fluid leaks are standard equipment on those. The guy I bought it from told me that if I didn't like leaks, I shouldn't buy an old Italian car. So at least I was forewarned.
Old Aug 7, 2022 | 10:35 AM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
I am keeping my mouth shut to keep the gods of AM repair away.
Old Aug 7, 2022 | 02:50 PM
MRCW's Avatar
When I had my PPI done on my 2009 V8V back when i bought it in 2017, the tech had a note about a slight weeping at the Timing cover... The SA at the Aston Dealer at that time gave me an estimate of about $2500+ or so and I used it as a negotiating point with the PO. It has never ever leaked dripped or weeped since. Fingers crossed
Old Aug 11, 2022 | 10:06 AM
Kalepsis's Avatar
5 Year Member
Kalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to all
I had a leak from the driver's side but it was refrigerant, not oil. Turns out the O-rings on the compressor lines were bad. Had them replaced and the AC serviced, now it blows cold again, which is good because it's been over 90 degrees here every day.
Old Aug 14, 2022 | 03:38 PM
kaveity's Avatar
kaveity is infamous around these parts
hi every body,
has any body repaired an oil leak from timing cover of 2007 vantage? I mean DIY
Old Aug 18, 2022 | 01:14 PM
Argus's Avatar
Look online. I remember seeing someone had fixed the cover without taking the front subframe off. AM says you have to remove the front end but it looks like this guy did it at home in his garage.
TJM007
Aug 9, 2021 09:42 PM
stanger011
Nov 3, 2017 02:00 PM
Collinsjd
Sep 18, 2016 02:05 PM
NFS13
May 22, 2013 03:44 PM
Mot282
Mar 27, 2013 01:17 PM
