parasitic power drain
Old Mar 5, 2023 | 01:58 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
Hi,
I finally put an instrument grade ampmeter on my DB9 and measured the parasitic power drain. I had been using one of my handhelds and the car would draw 2 Amps and almost immediately drop to .5A, and then go down to .02A at which point my meter would shutoff due to lack of use. I figured that .02A was well below what would be needed to drain a battery. I finally bothered to put one of my 6 digit / rack mount DMMs in series with the battery. It followed the same pattern but about 30 minutes in it jumped back up to .5Amps. No amount of locking doors/unlocking doors would make a difference.
I'm led to believe that US cars don't have the tracker that our UK colleagues point to as the key current drain culprit. Does anyone have any other suggestions beyond just pulling fuses? I am going to put it back on the lift at some point and start doing that but wanted to solicit advice before beginning.
And, as an aside, it was a gorgeous day here in the DMV to take the Volante on the road. Best car in the world to go buy groceries in!
Old Mar 5, 2023 | 02:13 PM
MRCW's Avatar
Originally Posted by AM4884
Hi,
Car alarm? Do you check amp draw if it's locked or unlocked?
Old Mar 5, 2023 | 02:41 PM
AM4884's Avatar
5 Year Member
Locked or unlocked made no difference...
Thanks,
Larry
Old Mar 5, 2023 | 03:37 PM
MRCW's Avatar
Really , the best way is to start pulling fuses or unplugging modules. Even cars over 10 years old have lots of modules that could cause a parasitic drain... Perhaps check Pistonheads as well.It could be as innocuous as a module not going to sleep. Most frustrating, good luck
Old Mar 5, 2023 | 04:40 PM
AM4884's Avatar
5 Year Member
thanks - fully prepared to pull fuses but thought I would ask in advance! I'll report back what I discover.
Old Mar 5, 2023 | 11:20 PM
hueyhoolihan's Avatar
hueyhoolihan is infamous around these partshueyhoolihan is infamous around these parts
i'm probably way off base, but rather than pulling fuses, i would think it should be possible to use the probes on a multimeter to check whether or not a fuse is in the process of conducting current. should save some time, if possible.
Old Mar 6, 2023 | 03:34 AM
AM4884's Avatar
5 Year Member
Thanks for the thought. I own a set of probes, but unfortunately, for these types of situations the current is measured in series with the circuit and not in parallel (like voltage). Thus to know how much current is flowing one needs to put the ampmeter in the circuit (in series).
Old Mar 6, 2023 | 11:18 AM
Geflackt's Avatar
Geflackt is infamous around these parts
Another tool to consider when going after parasitic draws is a thermal imaging camera. You can get these a lot cheaper now, some even connect to your phone and use the phone screen. You view the various fuse boxes and notice a slight temperature change in the circuit causing the draw. Warmer fuse is the circuit drawing power. I've not tried it yet, but I have a thermal camera and plan to try this the next time I'm chasing sleep currents.
Old Mar 6, 2023 | 11:34 AM
MRCW's Avatar
this is a great suggestion.
Old Mar 6, 2023 | 04:54 PM
AM4884's Avatar
5 Year Member
I own one... Given the ohmic loss across a fuse is close to zero I don't think I'll see it there, but the 6 W drain is somewhere in the car and measuring the boxes isn't a bad idea!
Old Mar 6, 2023 | 06:44 PM
a102768's Avatar
a102768 is infamous around these parts
I don't know how reliable it is but I did come across the voltage drop method a few years ago:
Old Mar 7, 2023 | 05:23 PM
AM4884's Avatar
5 Year Member
OK, that is actually impressive! Here's a link to the power probe chart: https://m.roadkillcustoms.com/wp-con...op%20Chart.pdf
VGLNTE1
Dec 12, 2022 09:11 AM
Dunnm
Feb 20, 2022 11:35 AM
Deanoroger
Mar 23, 2021 07:09 AM
Wildcat1212
Feb 18, 2015 11:28 AM
FLA996TT
Jun 22, 2013 02:51 PM
