2019+ TT V8 - Check your coolant
Old May 3, 2023 | 10:37 AM
I_gotta_Vantage's Avatar
5 Year Member
I_gotta_Vantage is infamous around these parts
A FYI for you that drive any of the twin T...
Check your turbo coolant reservoir to make sure you can see fluid in it... You dont have to remove the name cap... just shine a light on the side and you should see a pink/red level..
These engines evap a lot of coolant...
Old May 3, 2023 | 11:36 AM
volvodrummer's Avatar
volvodrummer
That should be a sealed system. I'd be adding dye and looking for a leak.
Old Jan 21, 2024 | 06:22 PM
Boris!2017's Avatar
Boris!2017
I just checked my turbo coolant reservoir and it is indeed low. Thanks for the tip. The reservoir is under a cover , so you would not notice this unless you are looking for it.. I would assume this is just typical diluted antifreeze / coolant in this system ? Or is it special Aston Martin red kool aid ?
Old Jan 21, 2024 | 09:47 PM
J doubleU's Avatar
Caution on this, it is not monitored and its more like a expansion tank and if you overfill it the system will let you know.by leaking. When the multiple pumps run at operating temperature that reservoir does fill. If you notice there are no low/high marks on it.
newporsche
Oct 21, 2021 02:40 PM
porsche510
Oct 14, 2011 02:35 PM
darmawaa
Mar 9, 2010 10:07 PM
996TTDave
May 29, 2008 11:55 AM
elduderino
Dec 14, 2004 08:17 AM
