SmarTire TPMS
Old Aug 10, 2023 | 11:18 AM
95viper's Avatar
95viper is infamous around these parts
SmarTire TPMS
I’ve been reading up on the SmarTire system which is on my 2010 Vantage mounted under glovebox. I changed my cabin filters and saw the plug unplugged. I plugged it back and all of the lights blink amber I have the original set of wheels on shelf and I am running HREs so I haven’t figured out if/where the original sensors are. I read about the aftermarket sensors and cloning them so I will figure that out next year when I am ready to replace the tires.
My question here is why I don’t get a dash light with it unplugged? I see redpants sells the tpms eliminator but mine is simply unplugged with no lights or warnings on dash.
Old Aug 10, 2023 | 12:26 PM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
I unplugged mine years ago with no dash lights appearing!.
Old Aug 10, 2023 | 03:29 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
I also run HRE rims..I bought the cable from red pants..works great..
Old Aug 10, 2023 | 03:48 PM
LuvBurninFuel's Avatar
5 Year Member
LuvBurninFuel is infamous around these parts
Are you sure they installed new TPS? I bought new wheels and tires, the wheel manufacturer mounted and balanced the new tires, TPS etc. I put the on the car and didn't get any TPS warnings. They paired instantly I assume.
Old Aug 10, 2023 | 04:29 PM
95viper's Avatar
Thx 07sportspack and Import. Strange how some need to redpants cable and others don’t.
Old Aug 10, 2023 | 04:31 PM
95viper's Avatar
I won’t know until next year what’s in the tires. I just was curious about the lack of dash lights when I unplugged the system.
Old Aug 10, 2023 | 04:33 PM
Import's Avatar
Yea..mine threw the dash light until I added the cable..mines an 08…go figure..lol
Old Aug 10, 2023 | 07:29 PM
MRCW's Avatar
Just started getting the tire code light on my 09. I'll try the unplug first.
Old Aug 10, 2023 | 08:54 PM
trainwreck's Avatar
trainwreck is infamous around these parts
I unplugged mine in 06 db9. No light
Old Aug 10, 2023 | 09:28 PM
J doubleU's Avatar
Pre 2008 you can just unplug with no warning. Onwards you need a plug in defeat or jump the 3 wires on the connector to disable. Easy to disable probe all 4 wires and connect the three that do not have power supply. So basically ground the 2 signal wires for warning and fault.
Old Aug 10, 2023 | 09:46 PM
95viper's Avatar
Just an fyi that this isn’t the case on my 10 Vantage. It is simply unplugged and no lights.
Old Aug 11, 2023 | 11:50 PM
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
I never tried just unplugging it, I plugged the jumper in and never thought about it, until these threads come up and I think about putting these sensors in. If somebody wrote a cloning sensors for dummies page I'd put them in, I need 8 tires right now!
Old Aug 12, 2023 | 07:48 AM
95viper's Avatar
If you have the original sensors then life is simple to replace with aftermarket. There is a barcode on them and you clone the new one with it.
if not the tool can read the old one. I watched a couple of videos and read up on it. Seems a little quirky but do-able. I’ll tackle it next year when I get new tires.
Old Aug 25, 2023 | 12:29 AM
Argren89's Avatar
Argren89 is infamous around these parts
There doesn't seem to be any rhyme or reason to it - I've seen some throwing dash lights for TPMS, others that don't
Kalepsis
Nov 14, 2020 12:40 PM
Jonhunt
Jan 4, 2019 09:52 AM
maxzboy
Apr 26, 2010 07:40 PM
camhabib
Sep 12, 2009 11:56 PM
wa1l1in
Jul 30, 2009 09:35 PM
