BULB FAILURE DIPPED BEAM error message
Old Aug 19, 2023 | 01:55 PM
seenastyle's Avatar
5 Year Member
seenastyle is infamous around these parts
I like being winked at but not like this . I’m getting the "BULB FAILURE DIPPED BEAM" error message. I know others have suffered from this, but this seems to be slightly different symptoms from what’s usually experienced, so the cause and recommendation may be different. But I’ll let all the smart folks on here illuminate:
It’s been happening intermittently for years, but recently more and more, and now it’s basically permanent. Always on the driver side (LHD). It’s only the main beam, meanwhile that side's eyelash / eyebrow strip works fine (whatever that’s called). I haven't noticed a discernible pattern so far like the weather/temperature etc affecting it. Thoughts?
Old Aug 20, 2023 | 07:12 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Likely a a bad ballast?
FYI: Earlier discussion of the same topic and sideline issues...
https://www.6speedonline.com/forums/...ce-please.html
Old Aug 20, 2023 | 08:12 AM
SemiF19's Avatar
SemiF19 is infamous around these parts
Sorry to ask a dumb question, but did you replace the dip beam? It's really easy and there are non OEM replacements that are excellent and really cheap compared to OEM.
Old Aug 20, 2023 | 10:00 PM
J doubleU's Avatar
Easy to check if you switch bulbs from side to side @ no parts cost. And inspect the connection at the balast for corrosion. How it works is the ballast fires the bulb to light, if it doesn't it will attempt to light it again and again. Then it gives up until the next off/on cycle. Ignition switched off. The way the ballast is mounted if you live in an area of humidity it tends to migrate in to the module. Denso ballast can be had for less than $100.
-JW
British
Bentley
Jan 24, 2023 10:49 AM
British
Bentley
Oct 20, 2020 08:27 PM
ciaka
Cayenne
Apr 29, 2018 09:38 PM
03EvoIII
Cayenne 955/957
Feb 16, 2012 11:07 PM
Mad Ness
Oct 3, 2009 08:57 AM
