Hatchback popper?
Old Oct 2, 2023 | 05:29 PM
mbrandt1402's Avatar
mbrandt1402 is infamous around these partsmbrandt1402 is infamous around these parts
Hatchback popper?
Just bought a 2012 V8V S that looks fresh from the new car showroom. I have to dig at the seam at the bottom of the hatch in order to lift it open, and I'm concerned that I will scratch the paint over time. Years ago I saw ads for door poppers for customized cars. Has anyone done something similar on a Vantage hatch? Or am I missing an easier way to open the hatch?
Old Oct 2, 2023 | 09:10 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
I have to do that too…will pull a finger nail sooner or later..it’s not much of a gap…and the rubber stops are as far out as they will go..
Old Oct 2, 2023 | 11:39 PM
msark's Avatar
msark is infamous around these parts
Folks ..... I had the same problem. Research and investigation showed me that the two (2) hatch poppers, one located on each of the lower corners of hatch had broken down. They are NOT bumpers but spring loaded.
These are inexpensive parts and easily replaced. Further, I installed a plastic glass cushion on the body of the car to add a bit more "pop". Here is the part number: 6G33-N40452-AB Bump Stop Assembly, Deck Lid
Enjoy one of the few replacement AM parts that sells for less than US$20.00 ....
Old Oct 3, 2023 | 12:24 AM
TR-Spider's Avatar
5 Year Member
TR-Spider is infamous around these parts
...after several years I found that the gap for the fingers is much wider in the outer corners...
Old Oct 3, 2023 | 07:23 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
I have a strip of PPF along the back bumper where it meets the trunk lid. Also needed to keep the CTEK plug from rubbing against the same area.
Old Oct 3, 2023 | 11:12 AM
Originally Posted by msark
Folks ..... I had the same problem. Research and investigation showed me that the two (2) hatch poppers, one located on each of the lower corners of hatch had broken down. They are NOT bumpers but spring loaded...
Thank you, msark!
Splitting hairs here, but they are actually a combo bumper and spring-loaded popper. The popper piston did not move freely on either unit, with one being much worse than the other. I sprayed a dry lube w/ Teflon into the body and worked the piston through its stroke several times, then repeated the process. I also adjusted the bumper body so that the hatch is perfectly aligned with the surrounding bodywork. This required extending it 2 turns on one side, one turn on the other. My hatch now pops up a couple of mm - enough to make it easy to grab the lower edge.
This was also a reminder that I really should do more investigation before turning to the forum for help. I've always been one of the guys that "figured stuff out" and then shared that knowledge on my previous vehicles. The Aston is a clear cut above those cars/rvs/offroad toys/race cars, but take away the gorgeous design and top-drawer materials and it is still a car, and I should be able to figure the simple stuff out.
Old Oct 8, 2023 | 05:43 PM
Lol, the most effective thing I've done, is to leave the hatch open for an hour or so. It now pops up enough to get at the lower edge. I don't quite understand why that happened, but I'm happy it did.
Old Oct 8, 2023 | 11:41 PM
msark's Avatar
You might also change the rear struts. There are the OEM's as well as some available with a bit more pressure to give a more powerful lift up
Old Oct 11, 2023 | 01:08 PM
Yup. Struts hold the hatch open just fine, so I'll stick with them for the time being.
Old Feb 23, 2024 | 02:48 PM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
Just an FYI, there is a BMW part for the same hatchback poppers: 51248187291 (buffer stop with ejector).
I just mounted them on my trunk and they fit perfectly.
Old Feb 23, 2024 | 09:59 PM
MRCW's Avatar
great find. Do they pop up the lid?
Old Mar 1, 2024 | 07:46 PM
EJ_Rapide's Avatar
Yes, just like the Aston ones. Gives you enough clearance to sneak a finger under the lid.
IJWS
Sep 27, 2023 05:11 PM
larryg
Apr 27, 2017 06:21 PM
handyman2009
Jul 19, 2016 01:12 PM
fredjchavez
Cayenne 955/957
Jan 22, 2010 10:32 PM
stearnsn
Dec 19, 2008 07:47 PM
