DB9 Headlight Crack
Old Nov 8, 2024 | 12:11 PM
bobdisp's Avatar
5 Year Member
bobdisp is infamous around these parts
DB9 Headlight Crack
I got home from a 3 hour spirited Interstate drive to discover this light crack on my 2005 DB9. When I first saw it I thought it would rub off. Is there a spot repair available?
Thanks in advance.
Bob D.
Old Nov 9, 2024 | 08:06 AM
Marmot's Avatar
5 Year Member
Marmot has a spectacular aura aboutMarmot has a spectacular aura about
Be careful addressing that, there is a film over the polycarbonate lens that will mar pretty easily. It's like a clear bra but it doesn't play nice with being polished or pulled up.
Old Nov 9, 2024 | 09:02 AM
V12Vin's Avatar
V12Vin
Yep it's a UV coating I believe. To OP, just let it be. You've enjoyed that 3-hour drive. Car is probably happy too. It's just a battle scar.
Old Nov 9, 2024 | 09:43 AM
bobdisp's Avatar
5 Year Member
Thanks for the tips. I'm thinking water now has a way in the the interior of the fixture. Should I add a protective film over both lights?
Old Nov 9, 2024 | 09:51 AM
V12Vin's Avatar
V12Vin
So it cracked all the way through?
PPF should be ok. I have them on mine.
Old Nov 9, 2024 | 10:17 AM
bobdisp's Avatar
5 Year Member
[QUOTE=V12Vin;4947215]So it cracked all the way through?
Hard to tell V12. I think I'll PPF both of them and be done with it. Thanks.
Old Nov 10, 2024 | 04:03 AM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
If it were me (maybe just me), I would mix up a small amount of CLEAR epoxy, use a needle or a pin and place a single drop at the center of the crack. That should seal any ingress to the inside of the HL and might even make some of the crack disappear.
From what I see in the pic, it appears to be just surface, but I could change my mind if I saw it in person.
All the Best with it.
Old Nov 10, 2024 | 08:15 AM
bobdisp's Avatar
5 Year Member
After very close examination it appears to be a scratch on the film. It was a wake up call. PPF is the answer for me. Thanks to all.
KiwiStu
Jul 1, 2023 12:25 PM
Rajah996
Apr 12, 2023 07:26 AM
gtmule
May 6, 2021 07:42 PM
All Mack
Apr 24, 2017 01:50 PM
Wildcat1212
Oct 19, 2015 08:51 AM
