Deck latch issues
Old Jan 5, 2025 | 02:39 AM
Francis2002's Avatar
Francis2002
Deck latch issues
Hello all my new friends!
On my DB9 Volante I have a frozen latch for the deck of the top. It is in the closed position and I can't get it to open. Any ideas on how to fix that without having to dismantle the motor that is hidden behind the rear window motor?
Francis
[img alt="Hete is the gap
"]https://cimg8.ibsrv.net/gimg/www.6speedonline.com-vbulletin/2000x1504/17360697689164068050493634740169_26616f0bcd6e8d270 f7580ebd690196f7afe8445.jpg[/img]
Here is the gap
Motor assembly taken from my parts car. I had to pry it from behind the window mechanism...
Old Jan 5, 2025 | 04:08 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
Have you tried putting 12V on it? It wouldn't surprise me that it is like the motors for electric parking brakes - runs till it torques out. Try running it backwards?
Old Jan 5, 2025 | 04:17 PM
Francis2002
I thought about it but the motor is inside a plastic box in two parts screwed together. 7 screws 6 of which are hidden by the widow motor/ mechanism.
The screwed panel on the box is fairly flimsy and could be cut with a cutter knife and glued back but it would be messy and still behind the window motor.
I may have to resort to that in the end.
Francis
Old Jan 6, 2025 | 04:25 AM
AM4884's Avatar
5 Year Member
I would just add 12v (from a battery tender/charger) to the connector at the end of the pig tail and see what happens. If it doesn't spin or gets hot, stop!
Unfortunately I have the coupe wiring diagram and not the volante. Sheets 17, 18, & 19 would be most informative if anyone has them!
Old Jan 6, 2025 | 05:43 AM
Francis2002
Old Jan 6, 2025 | 05:48 AM
PhuketPaul's Avatar
PhuketPaul is infamous around these partsPhuketPaul is infamous around these parts
All the wiring diagrams (including Volante) are in the DB9 workshop manual, link below
https://db9s.com/db9-manuals-and-brochures/
Old Jan 6, 2025 | 05:49 AM
Francis2002
Thanks,
Pictures of the rear-end damaged car.
Old Jan 6, 2025 | 04:42 PM
AM4884's Avatar
5 Year Member
Thanks for the links!
sliderule01
Sep 8, 2020 09:10 AM
Jonty1951
Bentley
16
Dec 11, 2017 11:58 AM
lilo1980
Bentley
Nov 3, 2016 08:50 AM
gliozzi
Bentley
Jul 20, 2015 01:30 PM
p556guy
Apr 9, 2014 09:28 AM
