How long do your warm up your engine?
Old Jul 20, 2025 | 01:06 PM
manuel2171s's Avatar
manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s manuel2171s
As AM4884 said " It takes a LONG time to get to an idle pressure of 21 PSI. It starts out a 71 PSI at room temp and gets down to 21 PSI some 10-15 minutes later."
how long do you warm up your engine, how many minutes, i wait between 3-5 minutes until the gauge move to the first white line. I have never skipped it.
same for the gearbox sport mode i wait 15 minutes at least.
Old Jul 20, 2025 | 02:07 PM
GA_DB9's Avatar
5 Year Member
GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !GA_DB9 Is a GOD !
I typically drive it right away after starting and avoid anything remotely spirited until it's just below the middle mark.
Old Jul 20, 2025 | 02:21 PM
i used to wait but 1,5 km away there is a superb straight line empty with pine trees you know its inviting you to accelerate and i did many time but will wait now.
Old Jul 20, 2025 | 02:31 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
I don’t idle for more than a couple of minutes…then drive sensitively until it reaches temp..takes me 8 mins to reach the highway…by the time I climb the on ramp ..we are ready to go..love second and third gears…lol
Old Jul 20, 2025 | 05:37 PM
a102768's Avatar
a102768 is infamous around these parts
As long as it takes to put my seat belt on, put it in sports mode and click OK on the Sat Nav.
Old Jul 20, 2025 | 07:05 PM
ragingfool35's Avatar
ragingfool35 is infamous around these parts
waiting until there is oil pressure is of course wise, other than that what are you waiting for? the parts will reach operating temperature very quickly once you start driving. maybe don't do donuts until then...
it takes me about 60 seconds from START to place phone in door strap, put AM accessory wrist watch on (keep in car), put keys in the armrest compartment, put on seatbelt, put on sunglasses, release parking brake, press AC button then recirculate button, then R button...
also i live in Florida
Old Jul 20, 2025 | 07:54 PM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
After cold starting (not really cold in FL) from I wait till I get movement in the temp gauge, 2 to 4 minutes. By the time I get to the highway, another 3-4 minutes we're up to temp and good to go...... for spirited driving another 5 minutes.
Old Jul 21, 2025 | 09:58 AM
53helofe's Avatar
53helofe
I tend to wait for the rpm to drop below 1000, but also in Florida so never any real cold start.
I would hope that the oil system is never really over pressurized even when cold.
Pushing any engine that has not reached its optimum operating temperature can result in excessive wear that is measurable through oil analysis but probably not going to be catastrophic.
Old Jul 22, 2025 | 10:20 AM
PC-V8V's Avatar
PC-V8V is infamous around these partsPC-V8V is infamous around these parts
I used to wait a full 10-15 minutes to be especially cautious. I only drive my car for fun so I'm never in a rush to get somewhere and am fine with waiting, plus where I live it can be chilly during driving season. Recently I've realized that the drive out of my neighborhood is pretty perfect for easing the car up to temp and waiting that long in the garage is unnecessary, so I've been cutting my warm up routine down to sub-5 minutes.
Old Jul 22, 2025 | 10:43 AM
embdenb's Avatar
I drive immediately but keep the revs below 3K until the temperature needle reaches normal. No need to rush this process. A new engine is probably more than the vehicle is currently worth.
Old Jul 23, 2025 | 03:05 PM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
I just drive and go. I don't push the RPM's until I feels like it's not dragging in the rear if that makes sense. In the winter than can be like 5-6 minutes of driving. I'll it keep it in auto until that point. The rest of the driving is always in manual mode.
Old Jul 23, 2025 | 08:54 PM
Davil's Avatar
Davil has a spectacular aura aboutDavil has a spectacular aura about
Drive and go but be mindful of revs until warmed up. This is recommended by all manufacturers.
Leaving your engine idling in a modern car to try and warm it up is very bad. They were never designed for this.
It causes oil dilution due to unburnt fuel, reduced lubrication and catalytic converter problems due to the length of time running cold.
Old Jul 23, 2025 | 10:52 PM
LuvBurninFuel's Avatar
5 Year Member
LuvBurninFuel is infamous around these parts
On cold start up I wait until the engine idles down. Have never timed it, but it is not long. Then drive reasonably until the engine warms up. Heard that that dry sump engines oil takes little longer to warm up. The transmission can be little notchy when cold as well.
Old Jul 24, 2025 | 07:57 AM
i knew abut the cat converter and idling. i ve seen the dealer waiting too, anyway its good to hear others recoemndations.
993Godspeed
15
Mar 19, 2025 02:52 PM
Shaqovic
Bentley
Mar 19, 2024 09:56 AM
hamlmarzooqi
Jun 24, 2013 07:43 PM
TraderJoe
Aug 6, 2010 09:19 PM
SHANKENFELTER
Tech / How To
Oct 7, 2009 10:12 PM
