V8VS makes a creaking sound from rear driver side ONLY when cold?
Old Dec 16, 2025 | 11:57 AM
VantageAston's Avatar
VantageAston is infamous around these parts
Have a weird problem that my dealer was clueless to identify...
In cold whether and only when I first move the car (i.e. reverse down my driveway apron / go over a speed bump) I get a fairly loud creaking sound coming from behind me (LHD) driver's side.
It's like metal creaking or metal on rubber. After say a minute, the creaking goes away and it's smooth again. It does not do this in summer, only below about 65f.
I'm worried that the problem might get worse or something is dry and needs lubricating.
Anyone got an idea of what to check?
Old Dec 16, 2025 | 12:26 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Something like this? https://aston1936.com/2018/08/11/rep...on-martin-db9/
I had this problem on my DB9. Changed the control arms and all was quiet.
Old Dec 16, 2025 | 01:34 PM
Thanks - Maybe but I'm not getting any squeaking at all. It's just a deeper creaking and it's been a year and not getting worse. Unfortunately he lists the part on that blog as being $250 but his link now shows a price of over $1000 before tariffs so $2k with and that's too much for something that doesn't affect performance .
Old Dec 16, 2025 | 02:48 PM
downeaster1's Avatar
downeaster1 is infamous around these parts
You can actually have the outer liners removed from the control arm bushings and then pressed back in. A shop did this for my vehicle and did both the front and rear for about $1500.
Old Dec 16, 2025 | 04:33 PM
yvr's Avatar
yvr
One man's squeak is another man's creak
I thought the cold weather symptom was the big clue.
Old Dec 17, 2025 | 08:53 AM
007JB's Avatar
007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light
I had that on my 13 Vantage for years, replaced rear upper control arm bushings with polyurethane ones, never heard again. OEM bushing has plastic case, they slide inside the arm bore.
Old Dec 17, 2025 | 07:31 PM
You know, you're right. I just checked the videos from AM1936 and he does the rears too, and describes my problem to the letter.
Annoying becuase my car only has 8k miles on but its probably an age thing as much as it's a mileage thing.
Old Dec 17, 2025 | 07:33 PM
Thanks, I saw the video from AM1936 and he does the bushing replacement. I'm thinking to do it myself. The bushings are only $250 and it's about 2 hours for both so I fancy having a crack rather than spending $1500.....
sultanattar
Cayenne 958
Feb 2, 2012 05:38 AM
mjb2503
Cayenne 955/957
Oct 29, 2011 04:29 PM
911stripper
Jul 5, 2011 01:17 PM
jeff4774
Mar 9, 2008 12:58 PM
ze_shark
Sep 27, 2007 08:40 AM
