2018 Vanquish S: Complete cooling system overhaul
Old Feb 1, 2026 | 03:26 PM
McKinneyMad's Avatar
McKinneyMad is infamous around these parts
Took my 2018 Vanquish S in for annual maintenance and was surprised that there was oil leaking into the cooling system. The techs could not identify the source of the leak, but best guess is it's a failed oil cooler. The tech did identify the issue as a failed oil cooler. There are no signs of coolant in the oil so that's a relief. The tech suggests a complete overhaul of the cooling system. Has anyone dealt with such a problem? I was surprised to see a similar chocolate shake even after multiple flushes but no driving.
This is what it looked like before it was flushed numerous times
When it was identified pre-flush
After numerous flushes (water and solvent).
Told there were numerous flushes with water and a solvent. This is what it looks like now.
Old Feb 1, 2026 | 06:22 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
Wow…that’s quite sludgy…good call on the multiple flushes…
Old Feb 1, 2026 | 09:57 PM
J doubleU's Avatar
Engine oil pressure is higher than coolant pressure, so a cooler failure could make sense at first. Going to be an involved process to find the fault. Either remove the cooler and test it or bypass and keep flushing. Good thing is oil in the coolant can be flushed eventually.
Old Feb 2, 2026 | 08:45 AM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
A buddy of mine had bought a Timeless Certified 2017 Vanquish and had a similar problem shortly after purchasing the car. Aston (Morries Aston Martin on Minneapolis) at first said it was not a warranty item (early days of the 'Andy Palmer' era), but eventually did cover it under warranty. Not sure what they replaced or fixed, but he eventually sold the car primarily because of the way he was treated by the dealership and Morries have since stopped selling and servicing Astons. I'm working with Aston Martin to get a local Factory service center (hopefully soon).
Old Feb 2, 2026 | 09:22 PM
Thanks for the response. Turned out to be the oil cooler.
Old Feb 2, 2026 | 09:31 PM
J doubleU's Avatar
Glad it has been sorted. Multiple flushes with Dawn and good water it should be good ??
Old Feb 2, 2026 | 09:32 PM
ugh..don't get me started. The drama is just beginning as far as the level of service. This is how my vehicle was returned to me. They are the official Aston Martin Service center here in Dallas.
Old Feb 3, 2026 | 04:32 AM
BWings's Avatar
5 Year Member
BWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond reputeBWings has a reputation beyond repute
It's really too bad about your Aston Service and AM service in general.
I just had my DB11 in the St. Petersburg (Tampa) Aston dealership (Dimmitt) for Key Fob programming and, luckily, the service was very good. Of course they did very little other than hooking up AMDS. I waited while the service was being done and they got finished in about an hour. I also requested they NOT wash the car.
I hear so many stories (some here on this forum) about owners completely abandoning the car BC of terrible dealer service experiences.
I usually will do anything to avoid a service experience, but in this case I couldn't DIY.
Old Feb 3, 2026 | 01:38 PM
007JB's Avatar
007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light007JB is a glorious beacon of light
https://www.youtube.com/shorts/Wf9oCPEespE
totally unacceptable
at .37 second in your video that coolant hose looks kinked or something not right. double check that.
Old Feb 3, 2026 | 01:42 PM
Import's Avatar
Truly wtf…
Old Feb 4, 2026 | 07:44 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Did you leave the dealership with the car looking like that? If you confronted the dealership on this, what did they say?
MadeInStuttgart
Jan 24, 2023 10:17 AM
buckarooboy
Oct 5, 2021 02:36 PM
Gambler
Feb 17, 2021 07:55 AM
rcollum
Mid-Atlantic
May 30, 2020 12:46 PM
Yazz911TT
Feb 12, 2012 08:36 AM
