Rapide ride height
Old Feb 9, 2026 | 06:00 PM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
Rapide ride height
Good evening,
I am looking at refreshing my whole front suspensions system, and the workshop manual is warning to pay attention to the "ride height" when tightening the nuts.
I just measured on my Rapide, one side is at 400 mm, the other side is at 380 mm.
Was wondering if a fellow Rapide owner could measure on his car and confirm the proper ride height.
Thanks in advance!
Old Feb 9, 2026 | 10:25 PM
EJ_Rapide's Avatar
Another thing I am thinking about: What could be causing the difference in ride height? A shot shock? A broken spring? Lower control arm out of specs?
Old Feb 10, 2026 | 06:52 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
How are you measuring the ride height?
Old Feb 10, 2026 | 07:46 AM
AAROND81's Avatar
AAROND81
Also make sure the car is on very flat ground, even a little unevenness can cause incorrect measurements. Can you post the workshop manual language? Not sure how tightening bolts can change ride height. This may just be a British translation issue and by ride height they just mean putting weight on the suspension before tightening control arm bolts.
Old Feb 10, 2026 | 10:07 AM
EJ_Rapide's Avatar
Sorry, this is what I meant with "ride height", the distance between the center of the rim to the car body.
Language of the workshop manual:
Old Feb 10, 2026 | 10:12 AM
AAROND81's Avatar
AAROND81
They're not saying you need to measure the height of the car, what they're telling you to do is put the weight of the car on the suspension before tightening bolts so that the rubber bushings are not twisted.
Old Feb 10, 2026 | 10:14 AM
EJ_Rapide's Avatar
I know, I know. I am just trying to identify which of my side is out of specs. I assume that's the 380 mm side, but trying to compare the ride height with other Rapide out there.
Old Feb 10, 2026 | 04:57 PM
EJ_Rapide's Avatar
Now, I just saw the video on Aston1936, and the ride height for the DB9 is 378 mm, so I am starting to wonder if the shock on the 400 mm side is the culprit...
Old Feb 10, 2026 | 05:42 PM
EJ_Rapide's Avatar
This is what the workshop manual calls for:
I wonder how many shops / dealers stick to these specs when doing the suspension work
DR3ADKN0T
Bentley
Jun 24, 2022 03:37 PM
smithk3933
Mar 12, 2010 03:50 PM
dreamtripper
Apr 29, 2008 02:49 PM
last911
Dec 31, 2004 09:43 PM
Dock (Atlanta)
May 25, 2004 03:09 AM
