Window Delamination
Old Mar 21, 2026 | 06:04 AM
rapideman's Avatar
rapideman is infamous around these parts
Window Delamination
Hello All,
I have a 2012 Aston Martin Rapide in good condition, but I am starting to see early signs of window delamination—specifically along the edges of the glass where the four doors meet in the center.
At this point it is not highly noticeable, but it is clearly beginning.
Here is my dilemma: I would like to proactively replace the window seals, as they are aging. However, I have been advised that removing/replacing the seals could cause the already-delaminating glass to crack or worsen to the point where it cannot be properly reinstalled. I have also been quoted close to $15,000 to replace the affected glass, which seems excessive relative to the value of the car.
A few questions for the group:
  • Has anyone dealt with seal replacement on partially delaminated glass?
  • Is the risk of cracking during seal replacement real in your experience?
  • Are there any workarounds (specialists, techniques, aftermarket glass, etc.)?
  • Would you leave the seals alone until the glass gets worse?
I am in South Florida if anyone has a trusted shop or specialist they would recommend.
Appreciate any insight—trying to avoid turning a minor cosmetic issue into a major expense.
Thanks in advance.
Old Mar 21, 2026 | 09:30 AM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
Old Mar 21, 2026 | 09:36 AM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
This is just a thought but is this a warranty item? Glass on a car shouldn’t delaminate. It is a safety problem that there could be a recall if it happens. I have never hears of a car having the glass delaminate.
Old Mar 21, 2026 | 02:44 PM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
Is the issue the window seal "only", or the window glass itself? How is it delaminating?
Old Mar 25, 2026 | 07:54 AM
rapideman's Avatar
The best I can explain it is that the window seems to be constructed with two pieces put together an interior piece and exterior piece that are stuck together. They seem to be coming apart. I am told I need to (sooner or later) replace all 4 windows. It looks like a $10,000 project that I am rally not willing to undertake. Otherwise the car is perfect.
Old Mar 25, 2026 | 08:00 AM
Marmot's Avatar
5 Year Member
Marmot has a spectacular aura aboutMarmot has a spectacular aura about
I would see if Safelite can help with this...
Old Mar 25, 2026 | 08:37 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Seems to be a fairly common problem with Bentleys too. Do a quick search on the Bentley forum here.
Old Mar 25, 2026 | 09:18 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Must be partly due to the glazing used for Aston Martin and the like's windows.
Old Mar 25, 2026 | 11:46 AM
Argus's Avatar
My Vantage windshield was hit by a piece of gravel causing a chip that turned into a bug crack. St. Louis Aston Martin charged $5000.
EJ_Rapide
Jan 13, 2026 10:15 AM
alanwestport
Dec 27, 2020 03:17 PM
charha01
Feb 17, 2016 10:16 AM
cavsct94
Sep 15, 2011 11:37 AM
softroop
Jun 30, 2008 01:07 PM
