Sponsored By:
Sponsored By:
My A4 is in problem, any idea?
Old Oct 27, 2012 | 06:15 AM
Tyson Hedley's Avatar
Tyson Hedley is infamous around these parts
well friends I am looking for some kind of suggestions from you people as my A4 is feeling Jerk whenever I just hit the brake. Not much versed with the technical aspects of car. Your suggestions will be appreciated.
Old Oct 27, 2012 | 12:15 PM
GETU1's Avatar
GETU1 is infamous around these partsGETU1 is infamous around these parts
Could be shot rotors, warped calipers. Take it in
Old Oct 27, 2012 | 01:22 PM
paericksen's Avatar
paericksen is infamous around these parts
an almost constant vibrating feeling during braking is usually warped or worn rotors.
a single thump could be a bad piston inside one of the calipers and indicates a more serious problem.
Old Oct 29, 2012 | 05:28 AM
Okay friends thanks for your response. I am going to check out all these stuffs as named by you the rotor and the caliper. One of my friend has also told me that it could be also because of torn brake pad...
Old Oct 29, 2012 | 05:25 PM
RADIUS's Avatar
RADIUS has a spectacular aura aboutRADIUS has a spectacular aura aboutRADIUS has a spectacular aura about
I have never heard of a torn brake pad. Good luck in finding out what is wrong.
Old Oct 30, 2012 | 04:27 AM
Well I checked all these and you are right there is nothing wrong with the brake pad but I found the rotor has wrecked. There is also some kind of rust on the caliper. Going to replace the rotor but is the rust may also cause some problem in future ?
Old Nov 1, 2012 | 03:05 PM
ECS Tuning - Audi's Avatar
ECS Tuning - Audi is infamous around these parts
If you're experiencing a shuddering under braking it could be due to uneven amounts of brake pad material built up on the face of the rotor. These inconsistencies will cause the brakes to pulsate.
Turning the rotors easily fixes this. Most shops can turn rotors for $15-$20 a rotor.
You'll want to re-bed your pads to keep this from happening again.
Good luck!
Jason
Old Nov 2, 2012 | 02:26 PM
dbcperformance's Avatar
dbcperformance has a brilliant futuredbcperformance has a brilliant futuredbcperformance has a brilliant futuredbcperformance has a brilliant futuredbcperformance has a brilliant futuredbcperformance has a brilliant futuredbcperformance has a brilliant futuredbcperformance has a brilliant futuredbcperformance has a brilliant futuredbcperformance has a brilliant futuredbcperformance has a brilliant future
We would not recommend turning the rotors on German cars. Most of these vehicles come with rotors that are made of rich iron/nickel material. Most of current cutting machines are not good enough to do the job. trust me on this. Also if the rotors are so warped, turning them won't help. Replace them when you can, with a set of pads, and do a proper initial brake in, and enjoy your car.
Old Nov 3, 2012 | 03:52 AM
Yeah, perhaps you are right, the best way to avoid the same in the future I should follow your instructions. BTW, grateful to all of you to guide me through right way. But, how such things happens, any idea?
Old Nov 8, 2012 | 01:48 PM
Originally Posted by 3t-jr
Time for new Rotors from ECS Tuning.
I'll be happy to provide anyone with quotes just shoot me a PM!
Jason
adnanm3
Nov 22, 2023 02:43 AM
PV=nRT.
Sep 9, 2022 06:06 PM
The Bogg
May 22, 2018 08:19 PM
nal991
Sep 11, 2015 09:05 AM
flewis763
Sep 10, 2015 01:08 PM
