Does your exhaust add power ? Good X- Flow read
Old Apr 19, 2013 | 08:09 AM
  #226
GT996's Avatar
GT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond reputeGT996 has a reputation beyond repute
Tim,
Originally Posted by Tim941NYC
The MoTec engineer I consult states my emap vs map is platinum 1-1 and under. golden is 2-1 emap vs map. Also it is worth noting that the lack of back psi lets the combustion chamber (heads and pistons) and entire engine absorb less heat.
I was told its thermal energy of the exhaust that spools a turbo (Why they heat wrap the header/turbine housing) and not the psi of the exhaust. My case proves that, no matter how hard it is for me to understand. I feel in order to move air/ gasses you need to have a difference in psi.
your setup for sure is like you say and I agree with what you are saying - but only for what you are doing. For the rest of us - or most of us - the emap vs map is more like 2-3 : 1. Having a lower backpressure is a good thing for all of us, that's no question. There is a point of diminishing returns though.
Going with a larger volume will bring the exhaust gas temperatures down by itself and this will reduce the kinetic energy. Wrapping the tubing and/or turbo will keep more of the gas energy in the tubes and hence reduces the losses and the only thing the system can react to it is a faster rotating/spooling wheel. That's why I have ceramic coating inside and outside my headers and the hot side of the turbo (see attached pic).
Of course you need a pressure difference to move air/gas, but it is always volume in combination with temperature and fluid speed that moves things.
Having said that, my new exhaust from 911tuning has a 2nd pre-cat O2 sensor style plug for doing ECU independent O2 measurements and also backpressure tests. Pictures will follow soon.
You see: there are some others who care about backpressure The probe on the pic is for EGT.
Regards,
Andreas
Old Apr 19, 2013 | 08:14 AM
  #227
Regards,
Andreas
very nice please share your results. what turbos are you using on your car ? looks like a factory style hotside.
#TeamAIM
Old Apr 19, 2013 | 08:45 AM
  #228
evil 996tt's Avatar
evil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud ofevil 996tt has much to be proud of
You get a lot of bad things going on with backpressure(ie small hot housings, etc). Exhaust valves, a/f ratio's etc.. it all suffers!
Tim, while your at it, install a turbo compressor "speed sensor" from Garret. A lot of great data fom that too. Knowing this is fantastic for plotting your turbo points.
Old Apr 19, 2013 | 09:07 AM
  #229
ttboost's Avatar
[QUOTE=evil 996tt;3826190]You get a lot of bad things going on with backpressure(ie small hot housings, etc). Exhaust valves, a/f ratio's etc.. it all suffers!QUOTE]
Don't I know it!! Stupid RS6 turbos...hot side the size of a plum...
Old Apr 19, 2013 | 09:25 AM
  #230
GT996's Avatar
Thanks, will do. The turbos are K24 2480 - 18Gs are close to them.
Old Apr 19, 2013 | 09:36 AM
  #231
Tim941NYC's Avatar
Tim,
Regards,
Andreas
Remember I am looking for full tilt for one mile at full power, Low end response is of no concern to me. Those turbos look like fvd's? They use all the caps to protect the stud's and cover the compressor. All data is good but you have what looks like the stock K24 hot side? which is restrictive compared to a T3 or Vband. I have etg's for each cylinder and each collector. When I get to the power level I am looking for I will move the collector egt to the outlet of the turbo.
Old Apr 19, 2013 | 09:38 AM
  #232
GT996's Avatar
I cannot sign that. I know that I have way too much backpressure. My current exhaust has had 2 cat sections on each side (making this a 200+300 = 500 cell exhaust) and my logging data shows the expected boost increase and better spoolup time when I lowered the backpressure by removing the 300 cell cat section (small surgery to the exhaust).
My a/f was always spot on - before and after - and not dependent on backpressure and by modifying the exhaust I brought down my 100-200 km/h time by almost 0.7 seconds. VE is affected by backpressure and the fuel is always monitored and controlled by the ECU.
It could just be the other way around: you lower backpressure, hence get way better VE and your fueling cannot keep up if it was at the edge before.
Logging is always a good idea.
Andreas
Old Apr 19, 2013 | 09:44 AM
  #233
GT996's Avatar
Tim,
your whole care is a full tilt I love it. The cops here would just drop dead if I would drive such a car here.
No FVD turbos. K24 that were on the car rebuilt to 2480 compressor side. Much like 18Gs from the flow capabilities. They were just there and the rebuild was a logical step with low costs compared to the next step. This will make me happy for about a year or two, I guess.
I am probably running half of the power of your car at the moment, so at best my car is good enough to warm up the track before you make your run.
Andreas
Old Apr 19, 2013 | 09:47 AM
  #234
ttboost's Avatar
How may lbs is that 2480 wheel? Bigger than 18G? Isn't the 18G wheel a 40lb wheel? Alphas are 48-50lb?
Old Apr 19, 2013 | 10:41 AM
  #235
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
2480 is a 41lb wheel but lighter than the 18g
Old Apr 19, 2013 | 10:48 AM
  #236
ttboost's Avatar
Thank you for the info.
Old Apr 19, 2013 | 11:42 AM
  #237
johnspeed's Avatar
Originally Posted by johnspeed
HEY I thought I would throw this out there..
If anyone wants to see how good their X-pipe is compared to a 100 cell Milltek system on my K24/18g car,my combo on signature,I am willing to Dyno it...But it can not be a full race system,non mufflered.. Street worthy..
I will pay for Dyno time and swap...If it makes more power with a nicer power curve I will buy it,if not I return it to you..
I have dyno time on May 15 on AWD Mustang Dyno at a shop called Boostin..
LOL...Hmm...No takers??..LOL..
LOL...I put a similar post out in a past thread of mine for an IPD test when I did a TB dyno swap and had NO response either??..LOL..
Old Apr 19, 2013 | 12:01 PM
  #238
Tim941NYC's Avatar
John,
If I sold exhausts I would send you one.. I will say some exhausts do have bungs weld on pre cat. Your milteck has them
Old Apr 19, 2013 | 03:51 PM
  #239
johnspeed's Avatar
John,
I know you would Tim..
EB Werks offered but there 3'' un muffled system would be to loud..
Old Apr 19, 2013 | 04:13 PM
  #240
evil 996tt's Avatar
John, I need to buy some flanges but, I'm going to start building mine if you want to see it and test it.(we live somewhat close by).
