Bentley Continental GT/GTC/Flying Spur DIY Thread
Old Mar 28, 2013 | 10:14 PM
  #61
sonicd0012's Avatar
sonicd0012 is infamous around these parts
I need a DYI for a headliner repair pretty badly, if anyone can share that would be amazing
Old Apr 8, 2013 | 04:48 PM
  #62
Douyon's Avatar
Douyon is infamous around these parts
is there a thread on how to remove a Bentley tire?
I see the tool to remove the B, but how do you remove the inner housing to get to the lug nuts.
Thanks and sorry id this is a silly question. I would rather ask then break something.
Old Apr 9, 2013 | 08:36 AM
  #63
jc_333's Avatar
jc_333 is infamous around these parts
Pull off the "B" cap then its two torx bits to remove the inner housing.
Remember to put the car into "jack mode" before jacking it up. Press suspension and car height button simultaneously and screen will show when its active.
J
Old May 3, 2013 | 10:05 AM
  #64
REDNOSEGT's Avatar
REDNOSEGT is infamous around these parts
When prying open the remote to change battery
Use the tool they provide in the trunk to remove the centre caps
It's nice and thin and works nice without causing damage to the plastic on the remote
Old Jul 24, 2013 | 06:03 PM
  #65
4KB's Avatar
4KB
4KB is infamous around these parts
Which v checker scanner model do you recommend to buy off ebay? So many different Choices. Thanks
Old Jul 24, 2013 | 11:17 PM
  #66
djjoonie's Avatar
djjoonie is just really nicedjjoonie is just really nicedjjoonie is just really nicedjjoonie is just really nice
v202
Old Jul 25, 2013 | 08:39 AM
  #67
REDNOSEGT's Avatar
I keep a vgate scan vs450 in my car at all times, cheap little unit from china works good,
For better reading get vcds and a cable I got mine from uk full working version with cable for 80, but it's not a authentic cable and you get no support from the company, but it was temporary
Old Jul 25, 2013 | 09:05 AM
  #68
4KB's Avatar
4KB
Any thoughts on the vgate vs450 vag scanner versus the v202 v checker?
Old Jul 25, 2013 | 10:59 PM
  #69
REDNOSEGT's Avatar
Save ur money get a vcds
The little scanner I got works for basic stuff it costed me like 45 or 50 shipped
I keep it in my trunk to give me a basic idea of what's going on , you can't get into all the faults
Anything else you need a vas or vcds
Old Aug 2, 2013 | 09:33 AM
  #70
Daddy C.'s Avatar
Daddy C. is a jewel in the roughDaddy C. is a jewel in the roughDaddy C. is a jewel in the rough
Hi Geo,
would you be so kind to pm me your DIY folder.
I've done some research myself and will give you feedback with additions, if any.
I'm Europe based and have info that applies to MY 2010 ( US= 2011) and earlier.
thx,
christian
Old Jan 9, 2014 | 06:56 PM
  #71
ExoticCarDriver's Avatar
ExoticCarDriver is just really niceExoticCarDriver is just really niceExoticCarDriver is just really niceExoticCarDriver is just really nice
Originally Posted by djjoonie
After a long research, I figured out how to disable the infamous TPMS Light.
First, pull the fuse #11 from the fuse box located in the driver side boot on top of the battery.
Next, get the Vag can bus scanner or ('v-checker' from ebay).
last, go to menu #19 from the scanner, hit coding, type in 0000006.
TA-DA~ light is gone!
Make sure you always check the tire pressure and enjoy!!
I tried this with my V-checker Pro V202 and it works! Many thanks to djjoonie
Please see the location for the location of the TPMS fuse to remove below.
Old Jan 10, 2014 | 02:03 AM
  #72
djjoonie's Avatar
Congrats!
Old Jan 14, 2014 | 11:44 AM
  #73
Does anyone know how to use VAGCOM to disable the rear aerofoil or remove the aerofoil light on the dash if I remove the fuse for it?
Old Jan 27, 2014 | 11:48 AM
  #74
Please note I have my personal reasons for disabling the rear aerofoil on my car. I figured out how to disable the aerofoil light on the dash. All you have to do is disconnect the connector going to the aerofoil motor (located between carpet and trunk lid) and then jump a wire from the No. 10 (rear aerofoil warning) and No. 4 (ground) locations on the connector. All the locations are labeled on the connector so you can't get it wrong. For safety reasons, I recommend putting a 1 amp fuse on the jumper wire.
I believe this works because when you disconnect the connection from the aerofoil motor, you are removing the ground from keeping the light off. The light needs a ground in order to keep the dash light off. Please see the attached electrical drawing for more info.
Old Apr 7, 2014 | 02:15 PM
  #75
kimpearsonusa's Avatar
kimpearsonusa is infamous around these parts
Your PDF file for Bentelys
Could you please send me your PDF for Bentley service parts etc.
I just bought a used 2009 GT with 35,000 mile
Thanks Kim
kimpearsonusa@gmail.com
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
