TPMS Light- turn off?
Old Feb 27, 2014 | 01:17 PM
jsmith141182's Avatar
jsmith141182 is infamous around these parts
Does anyone know if the TPMS dash warning light can be turned off, i.e disable the system? I know you can turn the system off via the infotainment but the dash warning light is still present. My car is a '04 Continental GT RHD
Old Feb 27, 2014 | 08:12 PM
ExoticCarDriver's Avatar
ExoticCarDriver is just really niceExoticCarDriver is just really niceExoticCarDriver is just really niceExoticCarDriver is just really nice
Old Aug 25, 2014 | 03:19 AM
jambo766's Avatar
jambo766 is infamous around these parts
GT TPMS light
Has anyone tried this fix?.. Can anyone recommend the Scanner.. Help with a step by step? Anyone in or near London that can turn the damn warning light off .. I am happy to pay them to do it!!
Old Aug 25, 2014 | 11:18 AM
pwc6t3's Avatar
pwc6t3 is infamous around these parts
First, pull the fuse #11 from the fuse box located in the driver side trunk panel on top of the battery.
Next, buy the Vag can bus scanner V202.
go to menu #19 from the scanner, hit coding, type in 0000006.
This worked perfectly for my 04 GT
Paul
Old Aug 27, 2014 | 11:09 AM
jambo766's Avatar
Tpms
Thanks for that.. where is the best place to buy the scanner, approx cost?.. and where is the socket that it plugs into located... any help would be appreciated...!
cheers
Old Aug 27, 2014 | 11:16 AM
pwc6t3's Avatar
cheers
I got mine off ebay, right around 100 bucks US. Shipped from China and arrived in 21 days. It plugs into a port near the drivers feet. On left hand drive car it is on the panel on the left side, on a right hand drive it might be reversed.
Paul
Old Aug 27, 2014 | 11:25 AM
jambo766's Avatar
Tpms
excellent thanks again Paul... I have spent a fortune on this system and it keeps going wrong... Bentley have just quoted me £1800 to repair the system... I say 'repair' .. they just replace all of the sensors and the control module. I have been looking for this fix for a long time!! Jamie
Old Aug 27, 2014 | 11:28 AM
jambo766's Avatar
pwc6t3's Avatar
Yes. V-checker 202 is what I have.
Old Aug 27, 2014 | 11:30 AM
pwc6t3's Avatar
So for 60 pounds you will have no more warning lights. You will have to remember to check your air pressure in your tires once in a while though. Good trade off in my opinion.
Paul
Old Aug 27, 2014 | 11:34 AM
jambo766's Avatar
It's a no brainer!! The beeping on startup drives me mad....
Old Aug 28, 2014 | 07:08 AM
ccwboy's Avatar
ccwboy is infamous around these parts
wow.so easy to fix.thank you
Old Sep 3, 2014 | 01:54 AM
jambo766's Avatar
Tpms
Hi Paul... I have ordered the scanner, but the supplier has told me that it cannot be used for programming and that it only reads codes?
Howe do I type in 0000006?
cheers
Jamie
Can you send me a picture of your scanner please?
Old Sep 3, 2014 | 06:24 AM
pwc6t3's Avatar
cheers
Jamie
If you get the V-checker 202 you can do much more than just read the codes, you can clear them and change some values.
Paul
Old Oct 29, 2014 | 01:24 PM
SF Car Guy's Avatar
SF Car Guy is infamous around these parts
BAD V Checker v202
I purchased a V Checker V202 but the connector does not fit my OBD2 port. Has anyone else had this problem? I contacted the seller and they acknowledged that they had a problem with their manufacturer. I wonder if someone can recommend a different OBD2 device that will work the same way as the V202. I want to turn off my TPMS.
Thanks you all for any help here. My 2005 GT was sold in US, if that makes a difference.
