Bentley GT Main Battery Dilemma
Rating: Thread Rating: 2 votes, 5.00 average.
Old Aug 3, 2025 | 01:15 PM
  #136
tmobileguy's Avatar
tmobileguy is infamous around these parts
Originally Posted by CUE99T
Surely like a boat the CCA size would indicate if its a Cranking battery......
Bentley uses a high torque starter which is more efficient. It can crank a larger engine with less draw...its equivalent to how gearing works where you can move a much larger object with less power depending on the size of the gear.
The H5 is used to crank the car and it has plenty of power to crank it with ease, which is why it sounds like it never struggles, unlike an H1 Hummer that has two batteries that it uses to crank the 6.5L diesel and still struggles with the 12v architecture that it was never originally designed for. The 24v Humvee cranks a lot better then the 12v civilian H1...
Antigravity Batteries
May 11, 2019 09:18 AM
May 2, 2019 12:19 PM
bc2041
Dec 28, 2012 09:26 AM
Mr. C4
Cayenne 955/957
Dec 28, 2011 07:15 AM
Vinnysca
Cayenne 958
Nov 2, 2011 07:37 PM
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
