04/05 Gt owners Hose issue $$$$
Old Mar 10, 2017 | 11:02 AM
Fonteno22's Avatar
Fonteno22 is infamous around these parts
ok any owners wanna touch on this issue once again i seen a 04 bentley gt 30k(just fully serviced ) miles for 40k but i wanna no how much did the hose issue cost u a the dealer also at a indy also with that many miles would u still buy the car knowing that issue is on the rise at any giving time i appreciate y'all honest opinions
Old Mar 10, 2017 | 11:28 AM
Fonteno22's Avatar
also would y'all do it if y'all had 40k for the car but 4k saved for when this issue happen and what mileage range did this happen with yours
Old Mar 11, 2017 | 03:02 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
For the hose on mine, the main dealer in the UK charged me the equivalent of $3,477 USD
That was at 53,000 miles, but it's doesn't seem to be a mileage specific problem from what I have read on here.
An Indy in the UK would normally charge around a third less for labour.
If the car has any signs of a rough idle then that's a sign that the hose needs doing.
A smoke test would give a definitive answer.
Les.
Old Mar 11, 2017 | 08:30 AM
Fonteno22's Avatar
yeah that's the same price my indy quoted me and ok so it's not s mileage issue and u said a way to check would be rough while idle or smoke when the car is just running
Old Mar 11, 2017 | 08:37 AM
Fonteno22's Avatar
also was this a one time fix or it has to be done mutiple times
Old Mar 11, 2017 | 10:53 AM
tarnow1942's Avatar
tarnow1942 is infamous around these parts
I wouldnt not buy an 05 because of this. Budget it in your purchase price. I did. If the vacuum leak occurs,pull the engine yourself or at an indi. Change the vacuum hoses to steel. Change the starter. Change the top O2 sensors,and enjoy the car for years.
Old Mar 11, 2017 | 11:58 AM
Johnny Hotspur GT's Avatar
Administrator
+1.
My 05 GT only has 8840K miles on it and the plastic vacuum tubes were cracked at the connection areas on said tubes.
You would do the replacement of vacuum tubes only once, you would replace them with steel tubes and not the dealer plastic replacement parts.
See my GT build thread for pictures of cracked plastic vacuum tubes.
https://www.6speedonline.com/forums/...-pictures.html
ID:	471594   Click image for larger version
ID:	471595   Click image for larger version
ID:	471596   Click image for larger version
Last edited by Johnny Hotspur GT; Oct 24, 2022 at 04:24 PM. Reason: Add information
Old Mar 11, 2017 | 12:23 PM
Fonteno22's Avatar
ok yeah my indy said the tubes would be steal once they have to replace it but is this the most expensive fix with the engine having to be removed and like the other person said once the engine is out do the starter and top 02 censors mind u the car only has 30k miles on it and was kept in a garage
Old Mar 12, 2017 | 03:50 AM
ExSF's Avatar
The only other expensive parts I've had to replaced were the discs and pads. I got them from a UK outlet for just over a grand and fitted them myself.
I also had to have the 'Mechatronic' module in the gearbox changed. The gearbox worked fine but the paddle shift wouldn't work. My Indy did that and that cost me £1,800.
He said that he had seen lots of cars like that but most owners were happy to not have functioning paddles.
Other than that, no major shocks in three and a half years.
Les.
Old Mar 12, 2017 | 06:17 AM
Fonteno22's Avatar
oh ok yeah see that's a good and nice run for the 3 1/2 years you had the car i also see yours didn't have the front end issue were the air shocks go and have to be replaced that's also real good
Old Mar 13, 2017 | 10:18 AM
ExSF's Avatar
Touch wood. No problems with the suspension.
Les.
Old Mar 14, 2017 | 06:41 AM
jim2331's Avatar
jim2331 is infamous around these parts
....please consider this, regarding the cracked plastic hose issue. It would seem that Bentley produced thousands (could it be 10,000) cars with this serious defect. Except for the very knowledgeable few on this forum, most people should avoid these cars....they are money pits and give Bentley a bad name. The VW Corp. presently is under serious ethical scrutiny and has been found guilty of major violations. The answer to this hose defect issue is that a half dozen original owners of these defective designed cars should sue VW to recover the $12,000 they were charged by Bentley Dealers to replace the defective plastic hoses.
....If I wanted a hobby car to take apart, I would by one of these defective cars...but would not pay more than $20,000 for one...There are thousands of these dogs out there and they are going to be sold by used car salesmen to the unsuspecting...a bad situation JimB
Old Mar 14, 2017 | 07:05 AM
Fonteno22's Avatar
yeah but what about when u replace the issue with the steal hoses it's just a one time fix and at a indy is a 4k job but seems like it's a one time fix and so far from my research this seems like the most expensive repair expense
355spider
Bentley
Feb 15, 2022 11:25 AM
DR3ADKN0T
Bentley
51
Jan 15, 2022 09:41 AM
Mauser
Bentley
38
Jun 13, 2017 03:09 PM
Max (SD)
Bentley
Aug 29, 2010 07:27 AM
